Old 06-11-2013, 10:28 PM   #1
VA72C10
VA72C10
VA72C10's Avatar
Need power steering low pressure fitting
Need the fitting that screws into the box and has a short section of metal tubing that you put the power steering hose onto. I have a new high pressure line but haven't been able to locate my low pressure fitting and the ones I've sen in the parts stores haven't looked correct.
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-11-2013, 10:42 PM   #2
truckdude239
truckdude239's Avatar
Re: Need power steering low pressure fitting
I bought my return hose from advance auto parts and it had that fitting in the hose witha pressure clamp just srew in and go ill see if i can find the number for u
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-11-2013, 10:46 PM   #3
truckdude239
http://m.advanceautoparts.com/mt/sho...009%7CL3*15710
Hose with fitting
David fuller
2000 Tahoe 5.3l 378
Old 06-11-2013, 10:48 PM   #4
truckdude239
Just the fitting
David fuller
2000 Tahoe 5.3l 378
Old 06-11-2013, 10:53 PM   #5
VA72C10
VA72C10
VA72C10's Avatar
Thanks a ton! I had them look it up in the store and they couldn't find anything. I will call and see if they stock either of those part numbers or order it.
Old 06-12-2013, 03:25 AM   #6
truckdude239
Np i broke mine i thought i was screwed till i found thoses
David fuller
2000 Tahoe 5.3l 378
Old 06-15-2013, 08:59 PM   #7
VA72C10
VA72C10
VA72C10's Avatar
looking at that again and it comes straight up. That would be into my inner fender...will see if I can bend it but does anyone else have an option they've used that looks more like the high pressure hose that lays flat against the frame with a tight bend coming out of the ps gearbox? Thanks
Old 06-15-2013, 09:04 PM   #8
VA72C10
VA72C10
VA72C10's Avatar
See this drawing on LMC...I can order one of these but would rather pick one up local because I need it within the next week.
http://www.lmctruck.com/icatalog/cb/full.aspx?Page=128
Old 06-15-2013, 10:17 PM   #9
pickupman
pickupman's Avatar
Jonathon, Inline tube carries the correct one. I do not think I have in stock but I will check for you tomorrow
atheystruck@comcast.net
67 1/2 ton 4wd custom cab
72 1/2 ton 4wd super cheyenne
71 1/2 BB super cheyenne shortbed
pickupman is offline   Reply With Quote
Old 06-15-2013, 11:10 PM   #10
VA72C10
VA72C10
VA72C10's Avatar
Thanks Bill
Old 06-18-2013, 10:46 PM   #11
mr_earnhardt1
I'd be interested in one too...any pictures to verify? Thanks!
mr_earnhardt1 is offline   Reply With Quote
Old 06-20-2013, 10:00 PM   #12
pickupman
pickupman's Avatar
Sorry, did not have any in stock
Old 06-20-2013, 10:40 PM   #13
VA72C10
VA72C10
VA72C10's Avatar
Thanks for checking. Do you know the correct part number by chance?
Old 06-21-2013, 08:30 PM   #14
pickupman
pickupman's Avatar
Cts7101
Old 06-21-2013, 08:34 PM   #15
VA72C10
VA72C10
VA72C10's Avatar
Thank you very much! Have a great weekend!
Old 06-21-2013, 11:08 PM   #16
Steve Cole
I need one too!
LMC charges too much for shipping when you just buy a cheap part or two, it's not worth it. Last time I paid almost 11 dollars shipping for a 5 dollar part.
Steve Cole is offline   Reply With Quote
