Old 06-11-2013, 11:25 PM   #1
A69C10
Header woes
Can anyone help me find a set of decent headers that will fit and not drag the ground. All I have seen are 400$ headers that well...wont provide 400$ worth of H.P. Any help would be nice. Thanks
A69C10 is offline   Reply With Quote
Old 06-11-2013, 11:41 PM   #2
BlackedOut67shorty
BlackedOut67shorty's Avatar
Re: Header woes
I herd headmans were pretty good, hooker is another choice but a bit pricier. Stay away from flowtech I have herd some horror stories about them
1995 s10 blazer 4.3
1967 c10 350/350 fleet short
1993 s10 blazer 4.3l 4l60 RIP 6/20/14
2000 mercury sable
Thats a how I roll
BlackedOut67shorty is offline   Reply With Quote
Old 06-12-2013, 12:40 AM   #3
A69C10
Re: Header woes
Will do... Maybe a little sparks going down the road aren't so bad after all haha
Old 06-12-2013, 12:50 AM   #4
67c10rustbuket
67c10rustbuket's Avatar
Re: Header woes
I have the new Hedman 69010 headers. made for our trucks and sit above the frame for maximum clearance on lowered C10s. Mine were $192 shipped and were later on sale at Jegs. Here is a thread about these headers. I have not yet installed mine but member Cubber has and there are pics of his.
http://67-72chevytrucks.com/vboard/s...d.php?t=577016
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
Old 06-12-2013, 06:54 AM   #5
Re: Header woes
I've had so many brands of headers over the years I can't list them all (or remember). I've never had any headers that hang below the frame. If they hang that low they're either not the correct application or made poorly by cheezy company. Just go with a quality header and you'll be good. They can be had for a reasonable price.
Old 06-12-2013, 11:40 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Header woes
If your rig is lowered more than 4"... which it sounds like it is. You will need to run 3/4 length or shorty headers. Pretty much the only options you will have with a lowered truck. Unless you have some custom long tunes made.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-12-2013, 11:46 AM   #7
Longhorn 70
Longhorn 70's Avatar
Re: Header woes
I bought a set from TKorinek here on the board. They were $225 as I recall and they ride about 1" lower than the frame. The collector flanges are not fixed which allows you to rotate them to the point of best clearance. Sorry I don't have under truck pics.
Also both sides were easy to install from the top. They came with gaskets and reducers but did NOT come with bolts.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 06-12-2013, 10:29 PM   #8
Re: Header woes
Gary
Not exactly. As I said in my post I've never had full length headers hang below the frame. Lowering the suspension has nothing to do with the relation between the engine and frame. I keep my exhaust up in the frame even on my 4wds so I don't tear the exhaust off when having fun. 3/4 length headers are a no go with manual transmission. My neighbor's '68 SWB I helped him with has a 4/6 drop with full-length headers and ZZ3/4spd It works fine on his truck.
Old 06-12-2013, 11:55 PM   #9
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
Re: Header woes
Doug Thorley tri-Y. I have the 3/4's, I believe. The collector adapters stuck out below the frame at a 45 degree. I took my truck to a custom exhaust shop and told them I did not want to see the pipes below the frame. He pie cut collector to flow straight back and eliminated the adapter.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 06-13-2013, 12:03 AM   #10
westbrookw
westbrookw's Avatar
Re: Header woes
72 SWB/Step
Old 06-13-2013, 12:31 AM   #11
Toxic Orange
Toxic Orange's Avatar
Re: Header woes
Longhorn_70, do you know the brand name on those headers? Looks like the same ones I have and have been wondering what they are.
Toxic Orange is offline   Reply With Quote
Old 06-13-2013, 12:56 AM   #12
jc70chevy
jc70chevy's Avatar
Re: Header woes
Chevelle headers will work on your truck and they tuck up higher in the frame i have them on my truck
jc70chevy is offline   Reply With Quote
Old 06-13-2013, 09:54 AM   #13
70blackfish
Re: Header woes
I just installed the new headman shorty headers, fit well no leaks, and dont hang low
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9
70blackfish is offline   Reply With Quote
