Old 06-27-2003, 03:35 PM   #1
72moneypit
72moneypit's Avatar
Help - Carb Backfire
I was driving to work today and started hearing/feeling carb backfires. I got nervous and exited the highway, and it seemed to drive OK. When I re-entered the highway, it started again... at about 55-60 MPH.
My question: What would cause a carb backfire at 55+ MPH, but otherwise it runs fine? I have to wonder if the outside temp (about 105) is contributing - I've not driven the truck in such hot weather since rebuilding the engine and installing the new carb.
Any ideas? Thanks!
Paul
72 Cheyenne Super Custom Camper
greenaz@hotmail.com
72moneypit is offline   Reply With Quote
Old 06-27-2003, 04:20 PM   #2
stelth2002
Young Gun wth Fast Inline
stelth2002's Avatar
fuel to hot? you sure its back firing or is it just like quiting. Could be vaporlock
1967 Chevrolet LWB with built 292! 415 ft. lbs of torque, 4 speed :O with 27% overdrive too, 3.73 Posi. Frame and body done... getting painted!!!
stelth2002 is offline   Reply With Quote
Old 06-27-2003, 04:33 PM   #3
Southpa
Southpa's Avatar
Have a looksee inside your dist. cap.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 06-27-2003, 04:40 PM   #4
72moneypit
72moneypit's Avatar
It makes a popping sound, and the engine lurches a little bit. Kind of like it's running out of gas (it's not).
Paul
greenaz@hotmail.com
Old 06-27-2003, 05:01 PM   #5
hanssolo
hanssolo's Avatar
Does kinda sound like fuel vaporization. I read somewhere the Edel. carbs need a heat insulator when things get hot, weather and engine, cause the fuel can boil in the bowls. Carbs like Holleys have the bowls hung on the outside but Edel/Carters have the bowls right on top of the hot engine. Dang! 105!
69 C10 longbed: 357c.i. /TH400/3.73s/AC/ beige primer/saving $ for paint
______________________________
hanssolo is offline   Reply With Quote
Old 06-27-2003, 05:15 PM   #6
lukecp
Formerly yellow72custom
lukecp's Avatar
You sure it's not running out of gas?
A clogged fuel filter will give you problems like that. I would go ahead and try it....a new filter is about $3 and takes 10 minutes to put in.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 06-27-2003, 08:27 PM   #7
cableguy0
also check the air filter i hadnt cleaned my foam filter in who knows how long and everytime i got to about 60 mph it would start hesitating realllllllllll bad on the highway stay under 60 and it was fine
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 06-27-2003, 10:58 PM   #8
'72 Shorty
I finally got an avatar
'72 Shorty's Avatar
Mine used to do that in the summer until I put the plastic spacer under the carb. That's with an Edelbrock 1407. I agree to check under the dist cap though, it could be carbon tracked and cross firing.
-72 C-10 short step (straight line only)
12.922/102.28
-69 C-20 on Propane (DD)
-69 C-10
-56 Mack B-753LS (tow rig)
-94 Chev K2500 Short Ex-Cab
-89 Isuzu Trooper...Kinda
-03 Kawasaki KFX-400
-05 Suzuki DRZ-400S
'72 Shorty is offline   Reply With Quote
