Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Tools, Shops and Shop Safety
Old 06-12-2013, 12:17 PM   #1
creed1969
Built a sandblaster!
Hey I thought some of you might be interested to see my sandblaster I built last month.
It started life as an 11 gallon portable air tank from Princess Auto, and the rest is just steel pipe fittings, square tubing, and some rubber hose. Here's some pics:
As you can see, I used 3/8 inch copper tubing to provide air pressure to the top of the vessel. It looks small, but once the tank is pressurized there isn't too much airflow to the top of the tank...just enough to replace the sand that is used, and whatever air leaches through the sand out the bottom.
I have seen sandblasters that use a ball valve or gate valve to throttle the sand flow, but was concerned that the flowing sand might erode the partially opened valve over time. So I used a throttling method I've seen on large industrial blasters, where a rubber hose is compressed by an adjustable clamp to vary the passage size in the hose. The rubber is virtually unaffected by the sand.
My welding is far from perfect guys, so take it easy... All I can do is practice... Here this one's a little better. And yes...I put it outside and did a pressure test to 120 psi while I hid in the shop. It seems solid.
The ceramic nozzle is the only part specifically designed for a sandblaster...I modified a 1 inch brass union to make a quick-disconnect to hold the nozzle.
And the bottom line is...it works just great! Total cost was just over $100.
Matt. 16:26
'08 Sierra Reg Cab, shortbox - daily driver
'69 C10 LWB, 250, 3OTT - summer driver
'98 STi Type-R (JDM) <SOLD>
'97 WRX STi (JDM) <SOLD>
creed1969 is offline   Reply With Quote
Old 06-12-2013, 12:45 PM   #2
rambler
MOVE OVER
rambler's Avatar
Re: Built a sandblaster!
nice job ! have you used in "in action" yet?
No matter where you are..... There you are...
Buckaroo Banzi
rambler is offline   Reply With Quote
Old 06-12-2013, 12:50 PM   #3
creed1969
Thanks, yes I tried it out on a brake backing plate and it worked great. My only complaint is my air compressor can't quite keep up as well as I'd like...might try a smaller nozzle size to slow down the flow and help keep the pressure up.
Matt. 16:26
Old 06-13-2013, 10:22 AM   #4
ETsC10
Hand Crafted C-10
ETsC10's Avatar
Wow! That is very, very cool!
Subscribed!!!
Forum Guidelines and Rules
Buying and Selling Code of Conduct
Become a Board Supporter!
Truck FAQ
Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member...
ETsC10 is offline   Reply With Quote
Old 06-13-2013, 12:30 PM   #5
RANGERdan
RANGERdan's Avatar
Nice Job. I found a plan for one on the internet and built one for myself. It does a great job but yes the compressor has a hard time keeping up.
RANGERdan is offline   Reply With Quote
Old 06-15-2013, 10:37 PM   #6
pritch
pritch's Avatar
Very cool
I built my own, also, but it is a cabinet type.
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 06-18-2013, 08:29 AM   #7
motornut
78K & 79C Jimmys
motornut's Avatar
neat setup!
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 07-04-2013, 11:01 PM   #8
hozeman469
I like your setup.I have a 30 something gallon craftsman vertical air compressor that's not any good and was about to throw it away to get it out of my shop...Looks like its time to buy some fittings and turn it into a sandblaster.Think it would work really well as one.
hozeman469 is offline   Reply With Quote
Old 07-05-2013, 12:41 AM   #9
Rufton
I plumb two 5hp compressors together to get pretty good volume; sometimes smaller compressors can be had on the cheap.
50ft of sloped metal pipe separates the moisture.
I use rubber fuel hose instead of expensive ceramic nozzles. Cheap and very easy to change out. Just pick OD my compressors can handle.
Rufton is offline   Reply With Quote
Old 07-21-2013, 01:42 AM   #10
72bowtiestepper
Very cool.....I like your idea of the rubber hose gate valve to regulate sand flow.....so what if your welding is not perfect....that is a nice project !
72bowtiestepper is offline   Reply With Quote
Old 07-21-2013, 07:13 AM   #11
Pop's C-10
Pop's C-10's Avatar
Nice job
1981 C-10 (Pop's)
1978 Camaro
2006 Lacrosse
Pop's C-10 is offline   Reply With Quote
Old 08-10-2013, 02:51 PM   #12
gofastnut
gofastnut's Avatar
Neat idea! I'm gonna have to scrounge around for a tank!
And a bigger compressor!
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
