Old 06-12-2013, 03:06 PM   #1
68_Step
Which grade of bolts
When replacing old tired bolts and nuts, which grade do you use for things that hang off the motor? Like power steering pumps, alternators... Grade 2, 5, or 8?
68_Step is offline   Reply With Quote
Old 06-12-2013, 03:11 PM   #2
Rufton
Re: Which grade of bolts
Grade 8 or OEM usually.
Grades 8 doesn't cost that much more.
I would avoid grade 2.
Often OEM bolts have grade identifier.
Rufton is offline   Reply With Quote
Old 06-12-2013, 03:12 PM   #3
MARKDTN
Grade 8 as much as possible. Not that much more expensive.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 06-12-2013, 03:13 PM   #4
54belair
54belair's Avatar
I always use grade 8 anywhere possible---need it or not.
1997 shortie stepside
1968 short stepside
1966 mustang
1966 chevelle ss
Dont always go the cheapest route--You can save yourself into the poorhouse!
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=489030
54belair is offline   Reply With Quote
Old 06-12-2013, 03:14 PM   #5
Longhorn 70
Longhorn 70's Avatar
YES grade 8. If it is in high moisture areas, stainless is good too. They are in between 5 and 8 for hardness but also resist rust. I use a few of them but they are pricier.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 06-12-2013, 03:17 PM   #6
JWSmith
Grade 8 - always.
I've lowered suspension on more than a dozen vehicles (granted, they were s-10's ) But you always use Grade 8
JWSmith is offline   Reply With Quote
Old 06-12-2013, 03:19 PM   #7
anubisani
anubisani's Avatar
always grade 8
anubisani is offline   Reply With Quote
Old 06-12-2013, 03:28 PM   #8
cdowns
cdowns's Avatar
aircraft grade stainless for most things that mount on the motor been doing it over 50years(pop worked for grumman) never had a problem with stuff fallin off due to bolt failures// i think grade 8 is way overrated for most things that guys use them for
Old 06-12-2013, 04:07 PM   #9
volksworld
factory used grade 5 for everything except high stress stuff like flywheel,clutch,and u joints...no reason not to upgrade to 8...but don't feel you have to run out and buy a grade 8 bolt when you have a 5 that fits
volksworld is offline   Reply With Quote
Old 06-12-2013, 04:10 PM   #10
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Grade 5 for brackets off the engine (alt, power steering, A/C, etc). Grade 8 is overkill for those.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 06-12-2013, 04:11 PM   #11
volksworld
don't know where the coffee cup came from...I never clicked on it !
Old 06-12-2013, 04:28 PM   #12
Longhorn 70
There are some things that may not be considered here. That is that grade 5 has changed. The bolts USED to be all US made when our trucks were assembled. US made unplated bolts had a higher tolerence than the foreign made of the time. They would be +30% -5% as I recall. That has changed.
I have had 3/8 grade 5 bolts break at 25 ft/lbs of torque DRY. Also the grade 5 of the day were not zinc plated in most cases which reduces strength by about 15%....
Spend the extra 15¢ a bolt and get grade 8.
Old 06-12-2013, 05:14 PM   #13
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
stainless for the engine!
John
1999 Toyota Tacoma 4x4
Old 06-12-2013, 07:47 PM   #14
68_Step
Looks like I will be using grade 8.
Follow up question: Where do you buy them? Locally I have been picking up grade 2, 5, and 8 at Orscheln' and Race Brothers - both farm supply stores that sell the different grades in bulk bins. Grade 5 is $2.99 per pound, grade 8 is $3.99. Should I be worried about buying from the bulk bins?
Old 06-12-2013, 07:50 PM   #15
68_Step
When I type random characters show up everywhere!
Old 06-12-2013, 08:31 PM   #16
54belair
54belair's Avatar
Nope,, just inspect what you buy. people have a tendency to look and put back "somewhere".
1968 short stepside
1966 mustang
1966 chevelle ss
My Build Thread
