06-12-2013, 10:14 PM | #1 |
What springs for Fatman Must.II
I have a 54 Chevy pick up with a Fatman Mustang II front end. It has a BB engine in it. My question is what front springs do I use. I had V8 Mustang springs in it with one coil cut off. The springs have now settled and the lower A frame is no longer parallel with the ground. A part number from NAPA or Ford or any supplier would be appreciated. Or if you have a similar set up and something has worked for you let me know. I am not opposed to using dropped spindles to get the stance I want. Right now the ride is way to stiff for me. Thanks everyone.
06-13-2013, 02:12 AM | #2 |
Re: What springs for Fatman Must.II
Only ones i know who would know is scotts hot rod and rob at nolimit both are members on here.
06-13-2013, 08:46 AM | #3 |
Good suggestion or what about contacting Fatman, telling them the info, & see what they recommend? I would start there....
