55-59 6-lug front disc brakes and original wheels
I just ordered a 6-lug disc brake kit today from CPP.
They tell me that my original wheels won't clear these brakes. He said they won't clear unless I have 3 1/2" backspace. I measured my wheels and they have 3 3/4" b/s. It does look like they would be easy to modify though. I think I could grind of the rivets holding the 2 pieces of the wheel together, slide the outer part out and weld back up. It looks like I could get up to 1/2" more backspace doing that. What do you think of this idea? I sure want to use my original wheels if at all possible. |
Re: 55-59 6-lug front disc brakes and original wheels
Why not run a 1/4 spacer from the tire stores and some longer studs in the hub (you may not even need them)?
Posted via Mobile Device |
#3 | |
I guess I'll have to wait and see what it looks like when I get them installed. I was hoping that maybe someone here might have already looked at this and know if it can be made to work. |
#4 | |
Stockton wheel company can do that mod for you
http://67-72chevytrucks.com/vboard/s...d.php?t=436442 |
![]() Join Date: Jun 2011
Moving the center on a wheel is not quite that easy. I have done it many times but you need some way to ensure they run true when you are done. I put an old axle in the lathe and bolt the center to it. Then silde the wheel hoop over the center and spin the lathe and tap it to true it up. I weld it while it is in the lathe to make sure it does not move.
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build |
#6 | |
