06-13-2013, 07:10 AM | #1 |
Project sixty nine
This is my sixtynine Chevy c10. I have had this truck for 18 years. This is my third time doing the truck. I changed the front end to a sixty eight. I welded everything together, the cowl, fenders, bed to the cab, the only gaps are for the hood and doors. I made a new windshield frame and welded it in. I wanted to glue the windshield and have a small molding like the new trucks. I redid all the gaps around the doors and hood. After welding everything I leaded all my seams and used Duraglass and Z grip to get the body smooth. In the interior, I made a custom dash and metal console. I am working on the hood right now. I did the the whole outer skin and took the peak out. I did a 4 inch body drop on the truck, for the frame I have a 79 nova subframe and c notched the rear. Will have a full air ride suspension. I will post more pics.
06-13-2013, 07:37 AM | #2 |
67-72 parts collector,…
Re: Project sixty nine
Wow.
We need more pics of your truck.
06-13-2013, 07:42 AM | #3 |
Subscribed to this...
1981 C-10 (Pop's) 1978 Camaro 2006 Lacrosse |
06-13-2013, 09:59 AM | #4 |
I will post more pics soon. If you are on Instagram, my name is blacklabmetalfab, on Facebook, db designs
Posted via Mobile Device |
06-13-2013, 01:02 PM | #5 |
Glad to see you on here! After seeing all those photos on IG, I'm still seeing details I missed before. Hood looks clean without the peak.
@zodiaceng |
06-13-2013, 01:08 PM | #6 |
Proprietor of Dale's Corner
Since you took the peak out did you have to add some support to keep it from oil canning?
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man R.I.P. FleetsidePaul |
06-13-2013, 05:04 PM | #7 |
i took out the factory bracing and made my own before i cut the outer skin off
06-13-2013, 05:06 PM | #8 |
06-13-2013, 05:13 PM | #9 |
06-13-2013, 05:18 PM | #10 |
heres the truck before i started doing the body work
Tags |
c10, custom, sixtynine |
