Old 06-13-2013, 07:26 AM   #1
1adam12
1adam12's Avatar
57 with camaro clip coil springs
My 57 has a 2nd gen camaro clip,Po heated the springs(WHY!!!!!)..so i bought a new set, did right side had cut 1 coil sat great..did left side now it sits almost 2 lower on drivers side...i don't know what i did wrong..would maybe turning coil in pocket raise it up or do I just have to buy another spring but not cut it..Not sure what to do any help ..Thanks for all the help !!
1adam12 is offline   Reply With Quote
Old 06-13-2013, 09:15 AM   #2
Speedbumpauto
Speedbumpauto's Avatar
Re: 57 with camaro clip coil springs
There is a clock position where the spring is seated. Because the spring isn't ground flat, there is a groove in the spring pocket that makes it flat, sort of. I'd guess you have one of the springs not seated properly.
Speedbumpauto is offline   Reply With Quote
