Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1973-1987 Chevrolet & GMC Pickups Parts Board
Old 06-13-2013, 09:28 AM   #1
modernbeat
modernbeat's Avatar
WTB '85+ GM Squarebody Hydraulic Pedal Set
Looking for a GMC-Chevy Squarebody pedal set for a hydraulic clutch master AND hydroboost brakes. This is for my '76 K25.
Not sure what you've got? The easiest way to check is if there are two studs pressed into the pedal bracket that go through the firewall.
Looking for the pedals on the left (Hydro/Hydro). The pedals on the right are vacuum/mechanical.
modernbeat is offline   Reply With Quote
Old 06-13-2013, 07:37 PM   #2
1968vetL-71
Junior Member
1968vetL-71's Avatar
Re: WTB '85+ GM Squarebody Hydraulic Pedal Set
I just pulled a hydraulic bell housing setup with slave cylinder, pedal assy, tilt 4spd column, trans and round np205 adapter w/shifter out of an 87 crew 1 ton. Are you needling anything else?
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 06-13-2013, 08:41 PM   #3
modernbeat
modernbeat's Avatar
I'm putting a NV4500/NP205 in my '76 using the Advanced Adapters bellhousing and clutch arm. So I don't need the adapters, bellhousing, trans or 205.
But I could use the pedals, all the clutch hydraulics and the tilt-standard column.
The pedals have to be from a hydroboost brakes truck. That's the only catch.
Old 06-13-2013, 10:34 PM   #4
1774btcrew
1774btcrew's Avatar
I have all of that stuff as well as a rebuilt tilt column that would be correct for your 76. I am sure you know that the 87 has the wipers on the column. I need to verify that the pedals are for hydroboost. I have 2 sets I am pretty sure one set is correct for you. Your dash emblem went out yesterday
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 06-13-2013, 10:50 PM   #5
modernbeat
modernbeat's Avatar
Thanks, I forgot about the wiper switch.
Please check the pedals and shoot me a price for the pedals and early column.
Old 06-13-2013, 11:45 PM   #6
1774btcrew
1774btcrew's Avatar
The brake pedals are different on each one. I know one of the pedal assemblies came from a 1 ton so it should be the hydroboost one. I want $150 for it. I will bump the ad up for the tilt column so you can see the pictures
Old 06-13-2013, 11:49 PM   #7
1774btcrew
1774btcrew's Avatar
I just looked and I don't have pictures of the 79-83 style. The big benefit of using these years is they bolt/wire up correctly for your truck and have the double D output shaft so you can use an intermediate shaft with Borgenson joints and get rid of the rag joint at the steering box
Old 06-19-2013, 08:47 AM   #8
modernbeat
modernbeat's Avatar
Back up as a reminder to guys that posted or PM'd me.
Get some photos and shipping prices of your pedals to me.
Old 06-19-2013, 08:59 AM   #9
My72BB
I'm parting a 89 K30 w/Hydroboost...I will have pedal assembly out later today and can get you pictures but mine is a Auto...Is that going to work?
I know you are putting in a manual...are you just needing frame work like in your pics or clutch pedal too?
Alan
My72BB is offline   Reply With Quote
Old 06-19-2013, 11:58 AM   #10
1774btcrew
1774btcrew's Avatar
Doing an ad right now with pictures of both pedal assemblies
Old 12-31-2013, 08:30 PM   #11
obijuan
ever find these?
obijuan is offline   Reply With Quote
