Old 06-13-2013, 08:03 PM   #1
williamsboys
williamsboys's Avatar
Question brothers rear mount gas tank?
I bought it and just wondering if anyone else has installed the same one. I have to cut my frame for the filler tub, but besides that the holes line up in the frame to the holes in the tank but it also came with j bolts. Where do the go? Could I just use long bolts threw the frame and tank then put a nut all the way up the threads for holding the tank to frame and another nut on the same bolt to hold up the strap.
Any thoughts would be greatly appreciated. I am working on it now.
Williamsboy
williamsboys is offline   Reply With Quote
Old 06-14-2013, 03:06 PM   #2
Trsmotrhed
Trsmotrhed's Avatar
Re: brothers rear mount gas tank?
I installed mine with drilling thru the holes like you said and not using the J vbolts. I can send pics later today. I didn't have to cut the frame though. You have pics you can post of what you're referring to?
Sold the 63 and have a 68 now.
63 SWB C10
LT1/4L60E, PS, PB, Disk Brakes, CPP 4" drop coil rear, 2.5" drop spindle w/ 1" drop coil. slotted rotors, front and rear sway bars. 18"x8" Cragar SS w/ 245/45R18
http://67-72chevytrucks.com/vboard/s...d.php?t=544174
Trsmotrhed is offline   Reply With Quote
Old 06-14-2013, 03:26 PM   #3
williamsboys
Thanks. I figured it out. I just had to piddle with it for a while.
Williamsboy
Old 06-14-2013, 03:28 PM   #4
williamsboys
http://
http://
http://
Williamsboy
