Old 06-13-2013, 11:09 PM   #1
ProStreet83C10
Drag Racer
ProStreet83C10's Avatar
83 C10 - No turn signals
hey guys, i went to a local cruise in tonight knowing i had no turn signals, figured it was flasher under the dash so on the way over i bought a new flasher, no luck, so i went on to the cruise in and when i got there someone told me i had no brake lights, so at that point i checked brake fuse, and it was blown. so i replaced fuse, got brake lights back but STILL no turn signals. So i asked a fellow club member, he came over and looked things over, he checked the top flasher, and it was very hard coming out - found rust on one prong and had a "rattle" when it was shaken. tried swapping flashers around and still no luck.
I also noticed that my 4 way emergency DO work, but my directional signals do NOT work.
No clue where to go from here.
Any ideas?
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
ProStreet83C10 is offline   Reply With Quote
Old 06-14-2013, 03:13 PM   #2
77c10
77c10's Avatar
Re: 83 C10 - No turn signals
I had a similar issue with my 77 C10 but mine was the tail lights and dash lights. The fuse blew so I put a new on in it and it blew again. I searched my truck with a fine tooth comb with no luck. Ended up replacing the harness from the firewall to the back of the truck and it fixed the problem. I tore my old harness apart and searched it inch by inch and could nver find the problem with it.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 06-15-2013, 10:24 AM   #3
ProStreet83C10
Drag Racer
well i hope that isnt my problem. i do know that everything worked fine before my buddy used it for prom. sometime during that night he said he lost the turn signals. only other thing i could think it would be is MAYBE the switch in the steering column.
Zach Hall
1983 Chevy C10
R/T: .194
60': 2.322
330: 6.379
1/8: 9.803
MPH: 71.37
1000: 12.781
1/4: 15.314
MPH: 88.79
