Old 06-14-2013, 12:12 AM   #1
cochino12
It followed me home?
cochino12's Avatar
air over leaf or 2-link?
I'm not concerned with laying frame, just want to be able to get the rear level or close to the front (lays crossmember) when aired out and I also want to be able to haul an open car trailer occasionally. Can I run a 2-link or aol without getting axle hop/wrap? This truck has mild 454 with roughly 425 hp/500 torque.
So, can I get away with running either of these setups or do I NEED to save some more $ for a 4-link? thanks for any input
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 06-14-2013, 12:29 AM   #2
davidfre21
Re: air over leaf or 2-link?
You sound like you want it all lol. A 2link with bag over axle should work pretty good for towing and getting low. It's the setup I'm planning on my Jimmy. The hp I'm not so sure about though, but if you don't beat on it i don't see why not. The main reasons of the 4 link vs 2 is the triangulation will keep your rear end centered and it allows the suspension to travel without pinion angle change.
davidfre21 is offline   Reply With Quote
Old 06-14-2013, 12:44 AM   #3
cochino12
cochino12's Avatar
yep I want it all AND cheap I don't mind the rear moving a little since I wont be running too large of a wheel setup. I'm not sure what size the bars are on the ekstensive kit, I'll have to call and find out.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-14-2013, 01:58 AM   #4
andrewmp6
Have you looked at porterbuilts trailing arm kit or ridetech?
andrewmp6 is offline   Reply With Quote
Old 06-14-2013, 07:06 AM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
4-link would be my choice.
Keith
Convert to disc brakes.
Old 06-14-2013, 08:26 AM   #6
SCOTI
SCOTI's Avatar
Nobody asked.... C10 or what?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-14-2013, 10:21 AM   #7
cochino12
cochino12's Avatar
I was leaning toward the dropmember but I read some reviews on the ekstensive 2-link and it seemed like a cheaper option that should do everything I need it to. I wasn't real sure of the strength of the bars, wheel hop...
'84 CCSB converted to 1/2 ton
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-14-2013, 10:23 AM   #8
blazer2007
If it,s for your blazer no one makes one,not a bolt in type.If you find one I will buy one too
blazer2007 is offline   Reply With Quote
Old 06-14-2013, 10:33 AM   #9
cochino12
cochino12's Avatar
not for a blazer, Nate did make me one for that blazer that was bolt it but I don't think he does that anymore.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-14-2013, 10:53 AM   #10
lolife99
lolife99's Avatar
There is a tone of articulation concerns with a 2-link, that have been argued back and forth since bags have been around.
Get a KP componets 4-link (not 6-link), with a simple panhard bar,... and add your bags where you want them.
Are you running a small c-notch or a step notch?
Keith
Old 06-14-2013, 04:30 PM   #11
Rochlow
I used a 2-link with a watts link in my 97 for years. 0 problems. Never trailered. It's still being used in the truck with no note problems
I know it's not the best design. However, i know of a few trucks that ran these with no issues.
///Relaxed Atmosphere
Rochlow is offline   Reply With Quote
Old 06-14-2013, 04:56 PM   #12
PBFAB.COM
PBFAB.COM's Avatar
The main concerns with the shorter 2-link are the amount of pinion angle change and plunge of the suspension through its travel... along with some performance and handling drawbacks when compared to other designs. There are pros and cons to EVERY design available. There are better options available... but they are also more expensive.
If you decide to go with a standard 2-link, the one recommendation I would make is to not run the bag on the bar, but mount a sleeved bag over the axle. This will give you a better set-up for driving and the occasional tow.
Nate
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 06-15-2013, 09:06 AM   #13
davidfre21
Aren't the trailing arm setups glorified 2links anyways? I haven't paid much attention to them sense mine isn't TA, but just laying it in my head. They seem about the same.
Old 06-15-2013, 09:25 AM   #14
SCOTI
SCOTI's Avatar
Yes & no....
The T/A set-ups are more than twice as long (51" on center), utilize I-beam construction (to allow some flex/twist), & are not parallel w/the frame (triangulated = more articulation). Those 3 factors make a big difference vs the low-cost aftermarket 2-link set-ups.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-15-2013, 01:11 PM   #15
davidfre21
My guess the I beam design was more about strength than twist. I can picture the triangulation in it though. And a two link bar can be any length
Old 06-17-2013, 08:26 AM   #16
SCOTI
SCOTI's Avatar
The I-beam most likely was for strength, flexibility..... & production costs.
And you're right... a 2-link can be any length. But, just like w/a Panhard bar, the longer the length of the bar the better the results. The factory front leaf mount that most people opt to use w/the common aftermarket 2-link set-ups yields less than 25" from C/L of the front mounting pivot to the rear axle C/L. The shorter length means alot more pinion change through the range of normal travel. I measured pinion change vs travel when I looked into doing this on my 74. It was something like over 6° of change w/4" of travel.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2013, 09:41 AM   #17
cochino12
cochino12's Avatar
Thanks for all the help guys. Nobody has mentioned anything about wheel hop/traction issues, any input there? has anyone actually bent a bar?
This may be a dumb question but if the pinion is set at ride height does the amount of change really matter? Assuming the truck is always driven at the set ride height.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-19-2013, 11:18 AM   #18
davidfre21
If set at ride height and drove at ride height then there shouldn't be any issue.
Old 06-19-2013, 11:32 AM   #19
SCOTI
SCOTI's Avatar
This is what I thought as well. After reading about the amount of change, I tested it myself over the 4" of travel I previously mentioned. Using a digital angle finder & benchtop vise to measure during travel (2" up/compression from ride height & 2" down/extension) = less than 3° w/the OE truck arm length & >6° w/the shorter 25" bar.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 06-19-2013, 12:07 PM   #20
cochino12
cochino12's Avatar
Which translates to premature ujoint wear? And any other issues?
Overall Im ok with the negatives of the 2 link when compared to the pricing of a bolt on type 4 link. As long as it will hande the power of the big block.
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-19-2013, 12:34 PM   #21
cochino12
cochino12's Avatar
Nate
Thanks for the advice Nate I think I will do that. I assume you guys decided not to release the 2 link you were contemplating?
Adam
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
Old 06-19-2013, 12:36 PM   #22
tinydb84
tinydb84's Avatar
I'm not going with a 2-link but I have a long bed with a two peice drive shaft. I figure if you can mount the front of the bars in line with the middle U joint then it wouldnt be as much a problem right? Just a though/wondering
David
Instagram: myfabguy
Old 06-19-2013, 12:39 PM   #23
SCOTI
SCOTI's Avatar
U-joint wear & driveline vibration.
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
