06-14-2013, 12:39 AM | #1 |
trouble stay cool.. (truck and me!)
Alright guys, I've been fighting this beast for weeks now I just can't keep my truck cool, It just keeps overheating and I don't know what to do..
This all started a few weeks back when I decided to replace my original hoses and flush out my radiator, replace the thermostat, this went good without a hitch, new hoses look good.. Well I noticed my water pump started weeping, oh joy, but that was easier than expected. I replace the water pump in what felt like minutes, filled the old girl back up, fired it up to take it for a test run and it started over heating. My radiator didn't appear to be flowing right.. I wanted to replace the old radiator anyways because it was kind of beat up and had a couple pinholes and some corrosion.. Soo, I have a friend with a couple spare radiators at his place a 3 core and a 4 core, that he was going to use in is 455 '70 buick skylark. It drops right in, easy as pie, once i figured out some size variables with attaching my hoses I filled her back up and went for another test fire.. It overheats again this afternoon The rundown.. I replaced all of my heater/radiator hoses, replaced my thermostat, replaced my radiator and upgraded to a 4 core, and replaced my water pump, and flushed the engine the best I could yet the old straight six still is overheating. Do I need to bleed the system? If so how do I do that? I primed the system the best I cold by making sure the hoses were full, I also stuck a garden hose inside my water pump and blasted a bunch of water back into the water-jacket.. I just don't know what to do now, or where to start? I was thinking about putting in another thermostat in case the new one is bad. It's a 250 straight 6, if anyone needs pictures I can take some. I just don't know what to do now, I'm reaching the limits of my mechanical know-how Thank you all for your time! Ya'll are awesome
1970 C20, SM465, Eaton Ho52, HD coils, NO PB/PS/AC, 250 I6, Wood bed. All original minus a tune up! http://67-72chevytrucks.com/vboard/s...d.php?t=545486 Gentlemen wear a bow tie. |
06-14-2013, 08:14 AM | #2 |
Old member
Re: trouble stay cool.. (truck and me!)
My first suggestion is fill it up and then get the front of the truck as high as you can u may have a air bubble in the system and it want cool down until you get all the air out.
Do u know the radiator was good since it was sitting around your buddies shop. there could have been debri inside it that is clogging the flow up.
06-14-2013, 08:45 AM | #3 |
2WD Jimmy
Is that a new radiator. If not, make sure it is profesionally rotted out, not just "flushed" at home as it were.
06-14-2013, 09:01 AM | #4 |
I've found air pockets in several different vehicles.
My scout was the worst as the way the upper host/t-stat housing is set up it's actually higher than the radiator cap. Easiest way to push an air pocket out in my experience is to take it out and flog it good. That will push the pocket out 90% of the time. |
06-14-2013, 10:21 AM | #5 |
I am a Referee of life.
My first suggestion is to get a thermometer and check to see if it's actually overheating.You may have a sender/gage/light problem since everything else is new.Also take the cap and have it checked.Watch when it's up to temp to see if the water is actually flowing.Also,look thru the fins and make sure air can flow thru them.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-14-2013, 10:40 AM | #6 |
Proprietor of Dale's Corner
You didn't accidentally put a reverse rotation pump in did ya
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
06-14-2013, 10:51 AM | #7 |
Is your fan clutch still good?
72 Chevy C-10 Project Big Easy! |
06-14-2013, 11:16 AM | #8 |
if u put a thermostat in wrong it will ovraheat
06-14-2013, 04:22 PM | #9 |
Not to my knowledge, I just got the one of two options at the o'reilies's a couple blocks from my house, $20 for a reman, $26 for new, I got the new one
06-14-2013, 04:23 PM | #10 |
There is no fan clutch, there is also no shroud on the 250 Inline engines, There is lots of airspace around the engine and the water jackets relatively thin walled so they didn't use fan clutches or shrouds until you got a v8, to my knowledge
06-14-2013, 04:24 PM | #11 |
Haha, no sir, I didn't put it in upside down, Put it in the same way as I took the old one out. I'm a rookie but I know not to do that >.>, thanks though!
06-14-2013, 04:28 PM | #12 | |
06-14-2013, 04:31 PM | #13 | |
06-14-2013, 04:34 PM | #14 | |
06-14-2013, 04:37 PM | #15 | |
Posted via Mobile Device |
06-16-2013, 05:29 PM | #16 |
Got her fixed! Had more air than coolant inside the engine.. Air gap under my thermostat that was insulating it from the fluid temp not allowing it to open up. Thanks guys! She's stayin' nice and cool, no shroud, no fan clutch, just straight fan and a new big block radiator!
06-16-2013, 06:41 PM | #17 |
Old member
Cool is Hot which means Cool!
