Old 06-14-2013, 01:23 PM   #1
72tutone
ECE 4/6 Owners pulling the trigger. Have some Q's
So I'm ready to pull the trigger on the ECE 4/6 kit. I have read numerous threads about meausuring prior to have a baseline. Right now my bed is off and I'm doing other work on it in which it wont be back on for sometime.
Is this going to be a showstopper for me? I can measure the front to the front fenders, but not the rear.
Any suggestions? Thoughts?
Should I proceed in purchasing? I would think actually have the bed off would make this install easier.
I just dont want to shoot myself in the foot, as I have saved for a long time to buy this kit and dont want to make a mistake.
72tutone is offline   Reply With Quote
Old 06-14-2013, 01:44 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: ECE 4/6 Owners pulling the trigger. Have some Q's
No.
Taking the bed off makes it ALOT easier.
Buy the kit.
ECE makes quality stuff.
You will like the 4/6 drop.
Keith
Convert to disc brakes.
Old 06-14-2013, 01:58 PM   #3
72tutone
Thanks lolife! Your help in 72blkbeauty's posting about the measurements was a superb idea.
That is what made me think of measuring.
With that being said, I think I will call Stan up
Old 06-14-2013, 02:05 PM   #4
bugmasta
bugmasta's Avatar
get the kit, you won' regret it. have the same setup on my rig and love it. wish i would have had the bed off my truck when i did mine, would have been way easier.
68 c20 build: http://67-72chevytrucks.com/vboard/s...d.php?t=358130
Club longbed ...cause girls like'em long!!!!!
bugmasta is offline   Reply With Quote
Old 06-14-2013, 02:39 PM   #5
Sklptrljay
Sklptrljay's Avatar
ECE is a great company who will make sure you are happy. In another thread I talked about how my front end was too high, ECE sent me new springs with return shipping prepaid. Turned out they had sent big block springs on accident.
Btw, it was my first attempt at dropping a vehicle and its not as difficult as I thought it would be. Just be cautious when you remove the front springs.
Good luck.
Sklptrljay is offline   Reply With Quote
Old 06-14-2013, 02:51 PM   #6
wgeyer88
I'm in the process of installing the 4/6 kit on my truck!
My project changed direction mid-build, switching from a LWB to a SWB stepside. Because the SWB uses different springs, I contacted them and they sent me different springs! Their customer service seems to be top notch.
Will
1970 CST10 SWB LQ4/4L80E
2004 Silverado (sold)
2007.5 Dodge Ram 2500
wgeyer88 is offline   Reply With Quote
Old 06-14-2013, 04:46 PM   #7
c10Dream'n
c10Dream'n's Avatar
I just installed the same kit on mine last week with the addition of 1" blocks in the rear. Needless to say I like the stance a lot more. I plan to finish the front this weekend.
Are you running a c-notch on yours?
c10Dream'n is offline   Reply With Quote
Old 06-14-2013, 07:43 PM   #8
Toxic Orange
Toxic Orange's Avatar
The ECE kits are well made and ride good. Adding a link to the thread Sklptrljay was referencing above so you can see a little more what to expect on the finished product.
http://67-72chevytrucks.com/vboard/s...d.php?t=583751
Toxic Orange is offline   Reply With Quote
Old 06-15-2013, 01:18 AM   #9
tmc1986
Great kit. I did the 4.5/6 drop (spindles were 2.5) with ECE power disc brake conversion. The kit went on without any problem. Everything is well made. I had a few questions about the installation and so I called ECE and they talked me through it. Great customer service.
'67 2wd LWB 350/4speed.
tmc1986 is offline   Reply With Quote
Old 06-16-2013, 12:34 AM   #10
2500HD
2500HD's Avatar
Buy the kit. make sure you paint the parts that are not painted before install. Rotors, calipers and master cylinder will rust in no time if you don't.
1970 Custom Original 400/400
Now ZZ454/4L80E/Edelbrock Pro-Flo 4/3:73 Eaton Posi
PS PB and cold factory air
Early Classic 4.5/6
Front 20X8.5 Riddler 4.75 inch bs Pirelli 255/40/20
Rear 20X10 Riddler 5.5 inch bs Toyo 295/40/40
Rear end is original wide 6 lug converted to 5 lug
2500HD is offline   Reply With Quote
Old 06-17-2013, 04:16 PM   #11
72tutone
Well. I bit the bullet and just now ordered my 4/6 kit. Big thanks to Stan for taking the time with me. I feel that this kit will be outstanding based on others, and the fact that Stan mentioned they will work with me should my stance not be correct with springs etc...
Overall quite pleased and the kit isnt even here
Old 06-27-2013, 11:07 AM   #12
72tutone
OK the kit was just delivered to my door a few moments ago. After taking everything apart, does ECE no longer stamp their name in the spindles? Mine are black and nothing to em. Was kinda hoping for their slick silver spindles with their name etched in em.
Old 06-27-2013, 11:52 AM   #13
First c10
First c10's Avatar
72tutone,
I put mcguaghys 2.5" drop spindles on my sons truck they looked the exact same.....funny is that both companies are in Fresno CA probably the same foundery, but they worked great I have had no problems. I have Mcgaughys drop up front 3.5" and ECE Drop leafs and shakles out back 5.5"
good luck take a few pictures before and after
Scott
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 06-27-2013, 11:57 AM   #14
lolife99
lolife99's Avatar
None of my ECE spindles have been silver.
They use to say Early Classic cast into them.
They for awhile ECE was having production issues and was shipping Western Chassis spindles.
I wouldn't worry about it.
ECE wouldn't send you an inferior spindle.
Keith
Old 06-27-2013, 12:05 PM   #15
72tutone
I certainly wouldnt think they would either, but I wanted to check to be sure. Also their shocks that came with my kit are the excel-g2 version. Mine are all black. I'm not sure if the other kyb's in the pic are different or not from their website. Or perhaps is because mine are a supposed "dropped" version?
I dont know. Again this is all of curiosity. I'm sure they are fine.
<Edit> Just looked at the part number on the shock 344068. Looks like they vary from black or gray.
Old 06-27-2013, 12:12 PM   #16
First c10
First c10's Avatar
Smile Re: ECE 4/6 Owners pulling the trigger. Have some Q's
I think the shocks are the same as the drop is almost all spindle which doesnt change the travel. if you use a drop spring of like 2" or more you may need a shorter shock.
if i am wrong someone will chime in! and if i am than maybe i need different shocks!!!!
GO GO!!!
Old 06-27-2013, 12:13 PM   #17
72tutone
First C10.
Yep they are McGaughys for sure. And I specified to ECE the 4/6 drop 2.5 spindle with 1.5" springs.
According to McGaughy's site I must use 1 1/4" rotors. Does anyone know if the stock rotors are this thick on a 72?
Check this link out from Jegs. Identical.
http://www.jegs.com/i/McGaughys/654/...rentProductId=
Old 06-27-2013, 12:26 PM   #18
First c10
First c10's Avatar
Ya mine are black like yours in the picture. They fit well the only thing I had to get was the backing plates. i got them from CPP off ebay the cheapest like 50$ shipped.
I live like 1 hour from fresno and know a guy that knows a guy!! you know ??? that is why i have mcguaghy front and ECE rear. but both make great products. I havent had any issues with either places products.
GO GO!!!
Old 06-27-2013, 12:30 PM   #19
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
My guess is that ECE makes them for MCGaughys.
71 Suburban 350/700R4 Project Trixie
72 CHEVY,Highlander,SWB,396,T400
BB72CHEVKT is offline   Reply With Quote
Old 06-27-2013, 12:38 PM   #20
First c10
First c10's Avatar
Actually I think Western makes them for both!!
GO GO!!!
Old 06-27-2013, 12:44 PM   #21
BB72CHEVKT
Junior Member
BB72CHEVKT's Avatar
http://www.earlyclassic.com/Tech.asp...=Drop+Spindles
Old 06-27-2013, 12:57 PM   #22
First c10
First c10's Avatar
Yeah i read that before but I think they are referring to the actual machined part that the bearings ride on and is pressed in the outer spindle part. but they are definitely the same product.
GO GO!!!
Old 06-27-2013, 02:29 PM   #23
CC69Rat
CC69Rat's Avatar
So, you aint done yet ?
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-27-2013, 03:11 PM   #24
First c10
First c10's Avatar
It's an old picture truck is done at least for the drop anyways. Check my avatar. This is with the bed off. Getting ready to relocate gas tank.
GO GO!!!
