Old 06-14-2013, 01:41 PM   #1
OSM 70 C20
OSM 70 C20's Avatar
Suicide Rims
My truck came with 2-piece wheels when I bought it & I replaced them with some new white spokes. I hate to get rid of them if there is some sort of value to them. Do people do full restorations with split wheels. Or are they only worth their weight in scrap?
"I taste Rust"
I wish I had the money my truck thinks I do
I taste "Patina"
OSM 70 C20 is offline   Reply With Quote
Old 06-15-2013, 08:01 AM   #2
elf w/capital T
Re: Suicide Rims
I would scrap them...
elf w/capital T is offline   Reply With Quote
Old 06-15-2013, 08:12 AM   #3
LockDoc
The Older Generation
LockDoc's Avatar
Re: Suicide Rims
I would think that anyone doing a 100 point resto would have to have them. I just put mine up in the barn.... I guess it depends on how much storage room you have. I would give mine to anyone that was close enough to pick them up but mine don't have tires on them.
LockDoc
Leon
Old 06-15-2013, 09:15 AM   #4
lowrollin70gmc
Too many projects
lowrollin70gmc's Avatar
Re: Suicide Rims
What diameter are they? I'm also in Fargo and would be willing to take them off your hands for you. (They aren't dangerous if you assembly them with a cage and cautiously).
Andrew
84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck"
70 GMC C1500 LWB My first truck: shaved, bagged, and more: the lowrollin70gmc
68 K20 Suburban 12V Cummins/NV5600/NP205/D60/11.5AAM 3.73s "Dakota Cadillac"
63 Chevy II Nova Coupe 250 I6/T56/4.56s "Economy car"
53 Willys Wagon 350/NV4500/BW4401/HP D44/9inch “Winter Wagon”
30 Model A 16 Focus ST
lowrollin70gmc is offline   Reply With Quote
Old 06-15-2013, 04:23 PM   #5
OSM 70 C20
OSM 70 C20's Avatar
Re: Suicide Rims
low rollin' they are 16", still have tires on them. They are yours. PM me
"I taste Rust"
I taste "Patina"
Old 06-15-2013, 04:36 PM   #6
skorpioskorpio
Re: Suicide Rims
Isn't this kind of like saying sharks aren't dangerous if you view them from the boat and cautiously?
skorpioskorpio is offline   Reply With Quote
Old 06-15-2013, 04:43 PM   #7
OSM 70 C20
OSM 70 C20's Avatar
Re: Suicide Rims
Handle with care, contents may blow your face off.
They are safe if they are in good shape and you know how to handle them. Older technology, so kids these days aren't used to them. But common up here in the Flatlands...
"I taste Rust"
I taste "Patina"
Old 06-15-2013, 05:48 PM   #8
mr48chev
mr48chev's Avatar
Re: Suicide Rims
When I put the mags on my 71 I ended up giving the split rims to some 80 something year old guy who still liked them old bias tires and all. When the tire store put my mags on they never let the split rims set, they were pulled off the truck and rolled right around and put in the back of the truck as they were removed.
On tire chain in the west has a standing policy that if an employe takes in a split rim and starts working on it he is fired on the spot. They had a few close calls and if you look around a lot of old tire stores you will see a cage with the bars bowed out from a ring coming off when they aired up a tire.
My ongoing truck projects:
Old 06-15-2013, 06:06 PM   #9
LockDoc
LockDoc's Avatar
Re: Suicide Rims
Ron, that works at the salvage yard two miles west of me works on them every once in a while. They don't have a cage.... I'll have to ask him if he has ever had one come apart on him.
LockDoc
Leon
Old 06-15-2013, 07:08 PM   #10
chiefcfd
chiefcfd's Avatar
Re: Suicide Rims
I changed many of these from age 15 to after 40.There are numerous 2 piece and 3 piece rims like this. Most failures are from people who don't know how to take these apart. They will spring the lock ring and it won't seat properly. The only tire I ever had blow up was not a split rim it was a new tire that the bead broke on. Nearly lost my nose with that one.
1972 Chevy LWB Roadster
1999 Chevy Silverado 2wd
2015 Chevy High Country 4x4 Crew Cab
chiefcfd is offline   Reply With Quote
Old 06-15-2013, 08:50 PM   #11
factorystock
factorystock's Avatar
Re: Suicide Rims
These are not " split rims " they are "lock ring wheels". Split rims refers to some medium duty truck 2 piece wheels that connected in the middle ( which was a very bad design). The 2 piece "lock ring" wheel is still being used today on heavy duty construction equipment and is the standard set up on container trailer chassis. Under shock loading or traveling over rocks and uneven surfaces, there is no air pressure loss that tubeless tires experience when the bead is broken for a split second. This design is an over kill for pickups, but back in the day, this was the recommended wheel for pickups hauling heavy loads. If they were so dangerous, GM engineers would not have used them up until the early 70's. No more dangerous than jumping a battery, you need to pay attention to what your doing. Most car tire shops will stay clear off them, but truck tire dealers still work on them everyday. These wheels are more expensive to deal with because of the tubes and liners which tubless tires don't have. For a 100% concourse restoration, which very few 3/4 tons receive, it is the only correct 16" wheel for '69 thru '72 C -20's.
factorystock is offline   Reply With Quote
Old 06-15-2013, 09:57 PM   #12
OSM 70 C20
OSM 70 C20's Avatar
Re: Suicide Rims
Yup. All true.
I was just sort of generalizing for the sake of brevity. I worked for a wheel and rim distributor for about 10 years, learned more than my fair share about wheels. To this day I can't stand it when people call wheels "rims"...
I just didn't want to dump something that may be of value to our hobby (hobby?)
"I taste Rust"
I taste "Patina"
Old 06-15-2013, 10:12 PM   #13
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Suicide Rims
I like stock wheels on a 3/4 ton but not all 3/4 ton had 16" splits - mine was outfitted with 16.5 x 8.25 steelies:
Old 06-15-2013, 10:33 PM   #14
LockDoc
LockDoc's Avatar
Re: Suicide Rims
My '68 CST/Custom Camper has the 16.5 x 8.25 wheels on it too. The only one listed on the SPID is the spare tire, which I thought was strange. I am the second owner of this truck.
LockDoc
Leon
Old 06-15-2013, 11:01 PM   #15
DeadheadNM
Carpe manana
DeadheadNM's Avatar
Re: Suicide Rims
LockDoc
Interesting Leon...the SPID on my K20 lists tire size for front, rear, and the spare (all 10" I believe) but not rim size. Here's a take off OEM spare wheel I have from a 72 K20 Suburban that's 16.5 with a 6" width IIRC. Sorry to hijack the thread - did 4wd 3/4 ton truck come from GM with split rims?
Old 06-15-2013, 11:20 PM   #16
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Suicide Rims
At least some of them did. My '72 K20 came with 16" split rims.... er, I mean lock ring wheels. Still have one of the originals as a spare.
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 06-16-2013, 12:08 AM   #17
lowrollin70gmc
Too many projects
Re: Suicide Rims
I'm saying it's safer to swim in a shark cage than trying to ride a Great White.
I've built many split (or lock) wheels for heavy equipment, both here in the US and while deployed overseas. When we didn't have a cage, we set a loader bucket or grader blade on top of the horizontal wheel/tire and stood behind a vehicle (up-armored MTVR) while airing up the tires with a clip-on lead and regulator at the air source.
Regular tubeless tires can explode while setting a bead on one piece wheels as well.
--PM sent--
Andrew
Old 06-16-2013, 12:53 AM   #18
Daner
Daner's Avatar
Re: Suicide Rims
I just saw a set a couple weeks ago when I was getting a tire on my air seeder fixed. They had already taken the grinder to them so there was nothing to salvage.
I've got one more year at NDSU. Do you guys ever meet up?
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 06-16-2013, 08:16 AM   #19
Katrina/10
Katrina/10's Avatar
Re: Suicide Rims
I'm glad you cleared that up.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 06-16-2013, 12:54 PM   #20
lowrollin70gmc
Too many projects
Re: Suicide Rims
I moved back to Fargo last year and will be starting NDSU (again) this fall. If any of ya'll need parts or a hand let me know. I haven't met up with guys from this board but I run to cruise nights in Fergus Falls, West Fargo, and Broadway in Fargo (a few blocks from me).
Andrew
Old 06-16-2013, 03:19 PM   #21
WIDESIDE72
WIDESIDE72's Avatar
Re: Suicide Rims
On a related note, someone posted a thread about the danger of inflating an almost flat tire on a front ender loader (the lock had come undone and blew up killing the operator). I wonder if this would be the same with our truck wheels. Seems to me it would be.
WIDESIDE72 is offline   Reply With Quote
Old 06-16-2013, 07:23 PM   #22
OSM 70 C20
OSM 70 C20's Avatar
Re: Suicide Rims
As long as no one laughs at my handy work, I'd be more than happy to meet up!!!
"I taste Rust"
I taste "Patina"
Old 06-16-2013, 07:36 PM   #23
1972RedNeck
1972RedNeck's Avatar
Re: Suicide Rims
The pickup "wheels" (what the difference between a rim and wheel?) don't have a lock on them. But yes, most anything can happen.
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 06-16-2013, 10:17 PM   #24
Daner
Daner's Avatar
Re: Suicide Rims
I googled this because I didn't know there was a difference...
The rim is the part where the tire is connected. The rim and wheel are typically connected by spokes.
There was a bigger distinction when hub wheel spoke rim were different materials.
I'll pm you guys or something this fall when I'm back.
Dane
Old 06-16-2013, 11:12 PM   #25
OSM 70 C20
OSM 70 C20's Avatar
Re: Suicide Rims
The distinction is even greater when you ship out a pallet of 24 truck rims instead of wheels...
I never thought this thread would evolve
"I taste Rust"
I taste "Patina"
