Do I need a new Rad Support?
Just what the title says. The front frame horn on the left side looks as though it was pushed in an inch or so. The fan shroud doesn't look to line up on the bottom (zip ties) and the top left crease looks a little extra bent. I'm trying to avoid fitment issues when all the painted panels go back on. Thoughts?
Also, i'm running a 4 core and would like a support that will hold this, are there any out there from the vendors that don't need modification for this fix? Thanks! |
"Ochre Ogre"
Re: Do I need a new Rad Support?
I don't really see a problem. Your zip ties don't matter. You are missing the spring clips that snap into the 2 holes that are directly in line with the holes in your fan shroud.
The only fab work to make a 2 or 3 core rad support is bending the bottom flange down so the lower cups are flat on the bottom of rad support. The factory looks like they used a hammer and chisel to bend it.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
#3 | |
![]() Join Date: Feb 2004
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
