Old 06-14-2013, 04:04 PM   #1
Tommyboy76
Fuel line problem plz help
This past weekend my father in law replaced my gas tank for me. It starts fine and runs fine but as soon as you give it some throttle it seams to really hesitate and bog down. The fuel line he replaced is clear and it really looks like air bubbles are going back into the tank. I assume that they should be going the other way or none at all. Could he have mixed up the other 2 lines which I assume are for venting?
Tommyboy76 is offline   Reply With Quote
Old 06-14-2013, 07:30 PM   #2
Tommyboy76
Re: Fuel line problem plz help
bump
Old 06-14-2013, 10:56 PM   #3
wraprail
wraprail's Avatar
Before you go any further, what kind of fuel line did he use?
I know of no fuel line that is Clear.
You can not use clear plastic hose as fuel line. (or anything else than is not rated for use with gasoline)
This is very dangerous.
wraprail is offline   Reply With Quote
Old 06-14-2013, 11:11 PM   #4
wraprail
wraprail's Avatar
As far as your question,
When you refer to the other two lines I assume you have 3 total?
What year and model is your truck?
Fuel injected or carb?
Usually you would have a 3/8" FUEL lline that goes to the fuel pump(from tank)
and a 1/4" RETURN line that also goes to the pump. (from tank)
and a 5/16" VAPOR line that goes to the emissons canister located on the radiator core support.
This is assuming your truck is a 81-86 non fuel injected.
If you have dual tanks then they go through that also.
All 3 lines are differant size so they should not get mixed up.
But again, you need the proper fuel line/hose to start with.
Oh yea, Welcome to the board!
Post some pics of your truck when you get things straightened out.
Old 06-15-2013, 05:50 PM   #5
Tommyboy76
The truck is a 86 carbureted single tank and yes there are 3 lines. If you were to mix up the return and the vapor lines would that cause my issue? If not any other suggestions. The truck ran perfect before the new tank.
Old 06-16-2013, 08:21 PM   #6
Tommyboy76
Anyone else have any input?
Old 06-16-2013, 11:17 PM   #7
pontgta
pontgta's Avatar
Yeah, the large line should be the supply, medium size return, and the small line the vapor/vent...
I would pull the tank down, and check the lines.. follow it to the pump.
pontgta is offline   Reply With Quote
Old 06-17-2013, 01:09 PM   #8
Tommyboy76
All the lines were correct. Removed the return line and started it up, it spit some fuel out. Which seemed to get the air it of the system. Still having the problem though. Going to change the fuel filter today and see if that fixes it.
Old 06-17-2013, 01:56 PM   #9
Low87
been here longer than Liz
Low87's Avatar
You need to deal with this ASAP.
~Greg~
Mac's Garage
'87 SWB 6/8 drop "Piso"
'08 CCSB Silverado DD
the departed
'89 GMC K5 Jimmy 4x4 "Rusty Nuts"
'77 Chevy K5 Blazer 2wd
'83 Chevy stepside
"You get what you pay for" - Mike 'swervin ervin' Ervin
Low87 is offline   Reply With Quote
Old 06-17-2013, 04:37 PM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
from my 79
3/8 feed
5/16 vapour
1/4 return
check the fuel filter,loosen the gas cap
don't use clear line,it will prob melt when heated
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-17-2013, 06:57 PM   #11
canadian trucker
A day should have 30 hours.
After you have driven the truck, you stop and loosen the filler cap, is there vacum built up?
canadian trucker is offline   Reply With Quote
Old 06-19-2013, 08:25 PM   #12
Tommyboy76
All the line were correct so I changed the fuel filter and it fixed the problem. I put a new filter in 5000k ago so I didn't think that would have been it. Glad it was though, thanks to everyone who replied.
Old 06-19-2013, 09:50 PM   #13
tucsonjwt
Man, I love reading these stories with happy endings. Better than watching cable TV. Congratulations.
tucsonjwt is offline   Reply With Quote
Old 06-20-2013, 09:14 AM   #14
motornut
78K & 79C Jimmys
motornut's Avatar
cool, time to burn some gas and rubber
John
Old 06-21-2013, 02:09 PM   #15
Low87
Low87's Avatar
Do you still have clear tubing as your fuel line? Just curious if you noted all the safety advice given to you above.
~Greg~
Mac's Garage
the departed
'83 Chevy stepside
Old 06-21-2013, 04:31 PM   #16
RastaRobb
RastaRobb's Avatar
I am wondering about the same.
RastaRobb is offline   Reply With Quote
Old 06-23-2013, 03:26 PM   #17
Tommyboy76
It was the first thing i did. i did talk to a few people about the clear line and they said there not very common but do exist. Not really sure maybe a Canadian thing?
Old 06-24-2013, 04:57 PM   #18
motornut
78K & 79C Jimmys
motornut's Avatar
doubt it's a Canadian thing,I've seen it used ,but not for pressured fuel,just vapour and overflow
John
