06-14-2013, 08:01 PM | #1 |
Would you powder coat your core support?
I found a good one a while back and finally got around to having it sand blasted.
I can get it powder coated for next to nothing at my BIL's shop, so I'm really thinking of having it done. It probably needs a little fine-tuning on the sand blasting end of it, but I only had to pay $10 to get it to where it is now.
'68 Panel Project Boogie Chillin' '68 C-10 Ol' Green |
06-14-2013, 08:15 PM | #2 |
Re: Would you powder coat your core support?
Mine is powder coated. It's super durable and looks good. Just make sure you do the right color cause its hard to change the color with powder
ANDREW 1972 Chevy SWB Cheyenne Super JANE http://67-72chevytrucks.com/vboard/s...d.php?t=462072 1972 GMC Jimmy PENNY http://67-72chevytrucks.com/vboard/s...d.php?t=735827 1968 GMC patina swb PEARL http://67-72chevytrucks.com/vboard/s...d.php?t=731315 1972 Chevy K20 BRUCE http://67-72chevytrucks.com/vboard/s...d.php?t=805788 |
06-14-2013, 08:30 PM | #3 |
I did mine gloss black. It is very durable and it makes it look far better than paint. Careful about the antifreeze it turns lighter colors, like silver, white. I would also spend some time and delete the ugly wrinkles that are on top of the top of the support. If your going to all the trouble to powder coat you might as well.
I know the isn't a great shot of the core support but you can see the nice clean lines that deleting the wrinkles makes. Posted via Mobile Device
I'd rather attempt something great and fail.. than try something ordinary and succeed. Norman Vincent Peale Project: Barn Raising http://67-72chevytrucks.com/vboard/s...d.php?t=414961 Project: 30 Be Low https://67-72chevytrucks.com/vboard/...d.php?t=830583 |
06-14-2013, 10:02 PM | #4 |
I am a Referee of life.
Think about grounds.You'll need to run wires or scrape new powder off to get good ones.Just something to keep in mind.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
06-14-2013, 11:51 PM | #5 |
Yeah, I have thought about the grounding thing. And I've often wondered if anyone shaved those 'wrinkles' mentioned, too. I would want to practice that on a junk support, first, though.
I would do satin black, same as my frame and stuff. I think I'll see my BIL this weekend. I'll find out what he'll charge me. If I can swing it, I think I'll go for it.
06-15-2013, 12:43 AM | #6 |
I would powder coat it.........
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
06-15-2013, 08:56 AM | #7 |
so easy a caveman can do it...
Would I? I did!
06-15-2013, 09:02 AM | #8 |
Yes. I powder coated mine as part of the freshen up, along with little triangle brackets, hood latch, motor mounts, booster brackets, bumper brackets, frame, trailing arms, etc. I did just about everything that was black except the inner fenders.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
06-15-2013, 09:06 AM | #9 |
Price being right it is a no brainer
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
06-15-2013, 05:03 PM | #10 |
Would you (have you done) your inner fenders as well? just worried bout the rocks hitting them from the inside. heard its hard to work with powder once its chipped?
06-15-2013, 07:13 PM | #11 |
I plan on powder coating those too, but doing line-x on the side towards the tires to keep the sound of rocks pinging down and because it should hold up pretty well.
06-15-2013, 10:01 PM | #12 |
I did everything under my hood including the inner finders, i say do it.
1967 swb 454 cid 700R4 trans SOLD 2006 Chevy Trailblazer SS 2013 Camaro RS convertible the wife's Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=573248 |
06-17-2013, 01:03 PM | #13 |
I went the same route, while I had everything apart I powder coated everything I could. The inner fenders I did a special coating called "wrinkle" black. it is a lot tougher than regular p.c. and it does not show any scratches from accidentally dropped wrenches while servicing your engine. Also if you have less than perfect inners this coating hides all of the dimples
06-17-2013, 02:12 PM | #14 |
Watch out for your cornhole !
There are 6500 different powders available currently. Candies, wrinkles, veins, you name it. Combine them with about 10 different clear coats from dead flat to full gloss and the possibilities are too many to count.
The wrinkle powder is great for making rough parts look smooth. Veins work well for that too and they add a bit more eye candy if you want it. Posted via Mobile Device |
06-17-2013, 03:07 PM | #15 |
As far as the grounds go just weld in a bolt or a stud that you can attach to after coating so that you do not have to scrape coating off.
