Old 06-15-2013, 12:19 AM   #1
wahl4m
1 ton dana rear problem ?
my 83 chevy -1 ton truck had a left wheel seal leaking ,checked 90 wt oil ?seemed to have some water in it ?? pulled both drums ! had some lite pitting on wheel bearings !!! im just worried about carrier bearings ?might be same way ? anybody had same problem ? should i have it torn down and checked ?to avoud trouble down the road ? pinion seal semms ok-no gear noise! ring and pinion look ok ! thanks for any info ??
wahl4m is offline   Reply With Quote
Old 06-15-2013, 12:31 AM   #2
meatwagon83
meatwagon83's Avatar
Re: 1 ton dana rear problem ?
change the fluid a couple of times, hopefully its not too late!
"DON'T TOUCH THE TRIM!!"-Early Kyler
meatwagon83 is offline   Reply With Quote
Old 06-15-2013, 08:52 AM   #3
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Make sure the air vent tube on the top of the diff is intact, and the end is bolted on as high up on the truck as it can go.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
