Old 06-15-2013, 12:59 AM   #1
1966FLEETSIDE
1966FLEETSIDE's Avatar
painting steering wheel
any tips on painting a steering wheel
1966FLEETSIDE is offline   Reply With Quote
Old 06-15-2013, 11:12 AM   #2
1963c-10
1963c-10's Avatar
Re: painting steering wheel
is it ready to paint or do you have cracks to fill? i used jb weld epoxy to fill my cracks and alot of hand sanding.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 06-15-2013, 11:17 AM   #3
1966FLEETSIDE
no not yet im planning on sandblasting it.thx for the tip on filling the cracks.do you use primer
Old 06-15-2013, 12:32 PM   #4
cortcomp
cortcomp's Avatar
I used pc7 epoxy, and 320grit sanding, then plastic adhesion promoter, then plastic primer then plastic gloss black. I'd be afraid sand blasting it would eat up the wheel instead of just cleaning it.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 06-15-2013, 08:33 PM   #5
rideblue00
rideblue00's Avatar
Do not sandblast it. I did that and it messed it up. Good thing i had another. I even used glass bead and that was too coarse. Sand it only.
rideblue00 is offline   Reply With Quote
Old 06-17-2013, 02:53 PM   #6
Dreddybear
Dreddybear's Avatar
Clean it real good with rags and lacquer thinner.
Then sand with 120 grit or so.
Find all the cracks and "V" them out with a hack saw blade.
Fill the Vs with PC-7 and let cur completely.
Then re-sand to smooth out where it's filled.
Make sure the transition is smooth and flawless.
Primer. Base Coat. Clear Coat. Good auto paint goes a long way here.
This is what I did to turn a giveaway POS 47 Ford wheel into the a pretty good looker. Took an evening and morning.
Before with tons of cracks that don't really show in the photo and nicks too:
After:
Dreddybear is offline   Reply With Quote
Old 06-17-2013, 03:15 PM   #7
Lugnutz65
Lugnutz65's Avatar
Visit my website to see my SW restoration instructions including videos. Just look through the subjects at the top of the page beneath the banner/header under the "more" section. I used KBS Coatings NuMetal to fill cracks but other epoxy putty works just as well. It will look good if you take time. It will look brand new if you take your time and then detail sand it before painting. I would recommend epoxy paint so the paint is as durable as possible.
My 65 C10 build: www.lugnutz65chevystepside.weebly.com
Want to know more about T5 transmissions? My website has a T5 Info Page and a Step by Step T5 rebuild.
Lugnutz65 is offline   Reply With Quote
Old 06-17-2013, 03:19 PM   #8
1963c-10
1963c-10's Avatar
I just sanded by hand w/some 400 grit and worked up to 800 after I filled the cracks. Like mentioned above, use a good quality primer that will adhere nicely and you'll be fine.
Old 06-18-2013, 12:14 AM   #9
1966FLEETSIDE
wow thanks for all the tips.
