lowered question
hi guys i have a 1968 chev truck and i was wondering how low can it go with a static drop i was thinking maybe 6 inches in the front but how low in the back can you go
Re: lowered question
I've seen 6/8 but not sure how they do it. I don't know if the quality of ride would be there at that point. I'm running 7" in the rear and it seems pretty tight. 6" ece drop spring and 1" block
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly ![]() |
![]() Join Date: Feb 2001
I think a 4/6 is about as low you can go with the need to make some additional changes.
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
Mine is cnotched but I know other guys run 6.5" with no issue
![]() Join Date: Sep 2012
I agree, I'm at 5/7 and I have barely a coke can heighth between the crossmember and the ground in the front and have a C-notch in the back for the added travel
hi jmorri34 do you have a picture of your truck with the 5/7 drop i would like to see that
i'm running the same set up with blocks. No rake in mine, sits level.
#8 | |
![]() Join Date: Mar 2012
You can go 6/8 but you will need a c-notch. You will start losing your ride quality when you go lower than about 5" in front unless you are on air bags. A "coke can" height under the front crossmember is tones of room. I bet the avg new corvette isn't able to drive over a pop can without knocking it over... My 78 is lowered 6/8 and I have no problems driving it anywhere. I have never once bottomed out and I haul my dirt bikes around in it every weekend. It's a nice ride height. Just don't try to do much off road driving off the beaten path.
#teamlongbed "I refuse to go disc brakes. I actually love drum brakes. It makes for an adventure." - 50bomb 1978 Chevy shop truck - static 6/8" 1970 GMC 1500 - Accuair eLevel Resto-mod http://67-72chevytrucks.com/vboard/s...d.php?t=537497 |
I would be happy to but I am out of the state right now and cant get any pics of it but the thread is on the build pages under the "ole 69er" if you wanna see some of the build pics, its still under construction, sorry fella!!
#11 | |
the truck has drop springs in the back but im not sure what size i would like to know because i dont want the back sitting lower than the front.The front i have it lowered
5 inches |
#13 |
I should think you would be more than fine with a 6 inch spring in the back and possibly even the 7, most kits are sold 4/6 and 5/7 and I havnt seen or heard of anyone being lower in the back ever. Maybe someone better in the know than me will chime in!!
#14 |
who sells a 7 inch drop coil for the back
#15 |
![]() Join Date: Feb 2004
well you can run 78-87 front end and get 3" spindles and springs. on 67-72 im pretty sure 2.5 is the lowest spindles you can get. imo 3" drop springs are too much. bad ride and alignment sux. you can get a 6" spring out back and a 2" block but you need a notch if you go with a block. some people make there own 3" blocks but this puts the arms real close to the ground not good! that is why I chose to go with the channel job, caus you get the low look with a better ride and geometry. and more arm clearance front/back
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
