327 Engine heads numbers
Presure washed my engine today and found these numbers on the Heads, I was told it was a 327 in a 71 c10 but not sure//
F09I4DA anyone know how to decode it I looked and could not find anything... |
Re: 327 Engine heads numbers
I am a Referee of life.
#'s on small block heads don't mean much.The heads can be swapped on just about any other small block of the era.Infact from 56-90's when they went to the vortec should all interchange.Get the numbers off the engine pad to determine the engine ci.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
That # is not a head #, its the block stamp in front of the passenger head.
F0914DA F=Flint plant 09=September 14=14th day, its not I4 DA= can be a 1965 283 or a 1968 307. Either one would have been a manual trans 3-speed with a 2-barrel originally. To confirm what it is you need the block casting number behind the drivers side head right where the bellhousing bolts on. The head #'s are cast into the head and you have to remove the valve covers to see them.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
