Old 06-15-2013, 02:38 PM   #1
camarodude87
camarodude87's Avatar
Why does my truck only have 3 gauges?
Hey guys Im in some need of information. Im pretty lost on where to find any information about these trucks on this site.
My truck only has Speedo, Blinkers, and fuel gauge... Its a Inline 6. 1970 SWB. 3 on the tree.
So my question is I would like to have the gauge cluster that has battery/ temp/ oil pressure etc. Would I be able to just buy that cluster and install it and just run my wires to whatever I had to or what.
Thanks guys,
Ray
2002 Camaro SS- AI Ported 92MM FAST / AI 226CC CNC'd 243's / Built T-56 / Moser 9 / T-Rex / 150 shot in the works / 6LE CME
SLP # 1716, 6-speed, Tan interior.
1970 C10 SWB, 250ci, 3 on the tree
http://www.youtube.com/watch?v=W1uw3TJhw2Q
camarodude87 is offline   Reply With Quote
Old 06-15-2013, 02:53 PM   #2
wgr2112
Re: Why does my truck only have 3 gauges?
Basically you have a "low optioned" truck. In order to use the full gauge cluster, you'll have to replace all or part of the wiring harness and maybe a couple of sending units.
wgr2112 is offline   Reply With Quote
Old 06-15-2013, 02:57 PM   #3
Mister-B
Thanks guys,
Ray
Most of the trucks I've seen with 3 gauges, are the 67/68 trucks. So, either somebody installed a 67/68 gauge after the fact, or I guess maybe you just have a very basic factory original gauge. You can buy a new cluster (or pick up a used one), and then run the gauges you need. My truck didn't come with a tach, so I added it after the fact, to look original. Wasn't too hard, and looks great. You'll need to run an oil line and what have you for the gauges you want
Here's a video I took of my first test drive with my new cluster with tach http://youtu.be/oRZNwEmaBy8
Mister-B is offline   Reply With Quote
Old 06-15-2013, 03:04 PM   #4
Andy4639
Old member
Andy4639's Avatar
U need the gauge cluster and the wiring harness for a factory gauge cluster. Junkyard both and get all the wiring out of the truck. Shouldn't be that hard to find. Oil gauge you will need the 1/4" line to hook up the gauge.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 06-15-2013, 03:13 PM   #5
camarodude87
Great looking Tach you got there. Im jealous.
Old 06-15-2013, 03:16 PM   #6
Mister-B
Thanks. Got it from the junk yard for like $35. Came with the tins and the circuit board too. It was a lucky score to say the least
Old 06-15-2013, 03:39 PM   #7
camarodude87
Thanks guys. Does anyone know of a place with some good info on these trucks
Old 06-15-2013, 03:46 PM   #8
no_rice
um... arent you on it?
no_rice is offline   Reply With Quote
Old 06-15-2013, 03:46 PM   #9
VA72C10
VA72C10
VA72C10's Avatar
This site Check out the FAQ threads for a TON of info. Krue's index goes over about everything you'd want to know. Including how you can add a dash with all the gauges with only swapping a couple of pins in the connector that goes into the back of the cluster and adding the hard line for the oil pressure gauge and the correct style temp sender
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-15-2013, 03:48 PM   #10
wgr2112
Mastering the search function will yield a LOT of good information!
As you have seen, asking questions will get you fast answers. Try to search the forums first, chances are someone else has or had the same question.
Welcome!
Old 06-15-2013, 04:05 PM   #11
camarodude87
thanks for schooling me on Forum etiquette fellas.
Old 06-15-2013, 04:07 PM   #12
camarodude87
Thanks for the guidance brethren
Old 06-15-2013, 04:23 PM   #13
wgr2112
We're all here to help each other!
By the way, thank you for your service!
Old 06-15-2013, 05:11 PM   #14
Lattimer
Lattimer's Avatar
Any of the trucks that came with low options can have the "idiot light" dash. That's what my 1970 has......until my new dash gets here.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 06-15-2013, 05:13 PM   #15
Lattimer
Lattimer's Avatar
Thanks guys,
Ray
You can swap one in, but you have a bunch of wiring to do and you have to go get the right sending unit for temp and run plumbing for the oil pressure.
Go here and scroll down a bit: http://www.gmcpauls.com/Tech%2520Tips1.htm
Shawn
Old 06-15-2013, 05:34 PM   #16
LockDoc
The Older Generation
LockDoc's Avatar
to the board....
There is a lot of different information in the FAQ forum. Scroll down to the bottom of this page and you will see the "Forum Jump" box. It lists all of the different forums on this board. Click on the little down arrow on the right side of the box and scroll down to "FAQ Truck Tech". On that page go down to "Thread /Thread Starter: FAQ Index thread". When you get into that scroll through the different sections and you will find answers to questions you haven't even thought of yet....
I could have just posted a direct link but there is a lot of good info in the FAQ section and now the people that read this thread will know how to get to it, and the forum jump box too. Thanks to Krue for indexing the FAQ's
You might want to check out the "Projects and builds" forum for some good info.
LockDoc
Leon
Old 06-15-2013, 05:36 PM   #17
Vintage Windmills
Vintage 4x4s
Vintage Windmills's Avatar
Even highly optioned trucks can have the basic cluster. I've got a loaded 67 GMC super custom with buddies, v6, PS, PB, AC and it has the basic cluster. The only thing that triggered guages to be installed was the gauge option (which would be on SPID) or the tach option (just tach on SPID).
67 GMC K1500 Custom- 305V6 SM420, PTO, Ram Assist, yellow (the outcast) (project period correct upgrades)
67 GMC C2500 351V6 TH400, AC, PS, PB (can't decide what to do with. Update, decided to keep and will restore )
86 CHV K30 502 th400, apple red NEW
71 CHV K20 350 SM465, ochre (saved work truck)
71 CHV K20 292 SM465, white, tach, PTO, (future project)
72 CHV K20 350 350th, medium blue (project stocker)
01 CHV K2500hd crew, indigo blue
^3 dont run and the others don't see winter either
'86 K30 Cummins "Fireside" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=649649
'71 K20 "get driveable" thread: http://67-72chevytrucks.com/vboard/s...d.php?t=590642
'72 K20 Build Thread: http://67-72chevytrucks.com/vboard/s...=493477&page=6
Vintage Windmills is offline   Reply With Quote
Old 06-15-2013, 09:40 PM   #18
Lattimer
Lattimer's Avatar
didn't know that. All of the higher option trucks I have seen had the gauges, so i assumed............
And you know how far that will get you.
Shawn
Old 06-15-2013, 10:38 PM   #19
Mustard72
Mustard72's Avatar
My 72 C20 only has the 3 guage cluster. I'm going to get some aftermarket temp/oil pressure/voltage guages, cut holes in the original dash, and put them where the factory would have put them. Might put a 4th one in for tranny temp, as well, seeing as though it will be a tow pig if I ever get done with it. I've seen where other guys have done this with the 3 guage cluster, as well, so it's not that original of an idea. You don't have to mess around with the wiring that much with this method.
FWIW, my 72 doesn't have much for any other options, either. Basically put together as a work truck I guess. Doesn't even have the cigarette lighter. Of course, back then, you didn't use the lighter for charging your cell phone...
Nick
Old Mustard, 1972 Chevy C20, 350, TH350, 4.10 Dana 60 rear, owned since I was 16 in 1986
http://67-72chevytrucks.com/vboard/s...d.php?t=545356
Blue Bell, 1987 K20, 6.2L Diesel, TH400/NP208, 4.10 gears
Ustahav 1976 K10, 350/350/203, Gov Loc, Yooper beater trail truck.
Mustard72 is offline   Reply With Quote
Old 06-16-2013, 12:44 AM   #20
FirstOwner69
FirstOwner69's Avatar
Same situation here. My 69 CST/20 came new with buckets/console, 350, auto trans, wood bed floor, power steering and everything that would have made it eligible to be a Custom Camper, BUT no gauges or power brakes. I had the dealer install power brakes as part of the purchase contract. Since I'm now restoring it, I've added full gauges (plus a tach) following the instructions provided on GMC Paul's website as well as a tilt and AM/FM. I fired up the engine for the first time this past week and all gauges work as expected thanks to GMC Paul! The rewiring was actually quite simple and about what an aftermarket gauge package would require. As I recall the gauge option was only about 10 bucks.
FirstOwner69 is online now   Reply With Quote
