292 gearing?
So here it goes got a 67 C10 with a 292 4spd. I'm pretty sure that it has 4.11 rear end. I want some highway speed out of this truck and I'm keeping the 4spd in it, so has any of you guys put in a higher ring and pinion and if so what did ya use?
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
Re: 292 gearing?
My 3/4 ton '67 with 292 had 4.56 gears so that is something you have to check on yours. I put 3.54 gears in the Dana 60 and with 32/33" 285/70R-17 tires it runs 70-75 on the hwy without issue.
'67 GMC 2500, 292, 4spd, AC |
so easy a caveman can do it...
![]() Join Date: May 2006
Re: 292 gearing?
I have a 3.73 posi trac rear behind my 292
Re: 292 gearing?
Ha Ha Almost answered My Question Lol
#5 | |
Re: 292 gearing?
Re: 292 gearing?
If it were my project I would look into swapping in a gm 14 bolt semi-floating axle. With a minor driveshaft adjustment you can just about bolt one in and the stock ratio is 3.73 and on the later ones ('90s, that I know for sure) you can get a six lug pattern which will still be different from the front but you can still use the same size rims. The whole ordeal will cost you about the same as the that of a new gear set as the semi floaters are really cheap and no one wants them in favor of the giant full floater which in your case would be severe overkill. Just my .02.
Rocinante: 1972 GMC C25, 292, SM465, 14 bolt, power nothing, 440k and still handles my PCS moves Jorge: Kia Roller-skate with lots of buttons for the wife Wovoka: 2017 Indian Chief Vintage, better on gas but not much So far, this is the oldest I've ever been. |
