Old 06-15-2013, 06:28 PM   #1
insanecloud
insanecloud's Avatar
brake question for belltech spindles
i have belltech's 3200 3'' drop spindles and i im planning on upgrading my brakes later and i was wondering if there are any disc brake upgrade kits/brands i cant use with those spindles?
thanks
insanecloud is offline   Reply With Quote
Old 06-15-2013, 08:49 PM   #2
mooseknuckles
mooseknuckles's Avatar
Re: brake question for belltech spindles
thanks
you can add the wildwood d52 4 piston calipers but I think that's about it.......most "big brake" kit use the CPP spindles...I pan on upgrading to he 6 piston 14" wilwoods later on.....
mooseknuckles is offline   Reply With Quote
Old 06-16-2013, 06:43 AM   #3
wraprail
wraprail's Avatar
The Wilwood "D52" calipers are 2 piston not 4. Basically just a fancy look. At $160 each they are quite pricey for a very small improvement over stock. They use the stock size rotor.
BTW, it's WILWOOD not WILDWOOD. lol
While on this subject,
Seems to me you could machine the factory caliper mounting "ears" off, leaving the threaded holes and with those and the dust shield mounts you would have enough to mount a custom bracket.
Then all you need to do is machine a stock rotor down to just a "hub", Redrill a pair of Cadillac CTS-V 14" front rotors to 5x5.
Slide rotors over home made hubs. Install 2004-07 Cadillac V Brembo 4 piston calipers on your custom brackets and done!
KILLER 14" Giant brakes. Cheap!
Ok ....I designed it....somebody go build it.
wraprail is offline   Reply With Quote
Old 06-16-2013, 10:31 AM   #4
mooseknuckles
my bad.....
Old 06-16-2013, 12:07 PM   #5
lolife99
67-72 parts collector,…
lolife99's Avatar
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=465140
Keith
Convert to disc brakes.
Old 06-17-2013, 04:51 AM   #6
insanecloud
do those work on the belltech spindles?
Old 06-17-2013, 06:03 AM   #7
lolife99
lolife99's Avatar
No.
They are modified spindles sold by member way2lo2.
You have Belltech spindles designed for the 73-87 light duty 1" rotors.
These spindles also use a different caliper than the 73-87 HD 1-1/4" rotor style drop spindle.
(3100 in Belltech's version)
To upgrade your brakes to a bigger brake system,... you will have to use the spindle recommended by the brake supplier.
Keith
Old 06-18-2013, 05:13 AM   #8
insanecloud
No.
The use spindles also use a different caliper than the 73-87 HD 1-1/4" rotor style drop spindle.
do you know any brake suppliers that recommend belltech spindles?
