Old 06-15-2013, 06:31 PM   #1
dhart
dhart's Avatar
Talking Big Block Tig Welded Custom Exhaust..
If you have or you are building a big block for a 67-72 C-10 I can tell you this is as nice of a professionally built exhaust system you will find.
It was built by a local high end fabricator here in Memphis and I can send you a link to his site if needed.
It was built for a high end 67- C-10 with a 565 fuel injected big block and it will fit fine on any standard short deck block and heads from 402-632.
It consists of 2 1/4 primary tubes, merge collectors to 3 inch Heddman x pipe and extensions. It was all hand tig welded, pipes are numbered and then sent out for jet hot coating.
I can tell you the fit is great with good ground clearance as well, two tubes go over the frame and plug access is excellent. This is not a one size fits most set of hookers, the build quality is as good or better than a set of Lemons headers.
The cost of this system was around 2000.00 It was used for around 2500 miles and pulled for a top shelf L/S swap.
I bought the engine and all associated parts that I am installing in my chevelle. I wanted to keep the exhaust for a future c-10 project but have decided to pass it on.
No issues with this one, no leaks, very very nice!
875.00 firm....... Reduced 750.00 plus shipping!
shipping 100.00 continental u.s.
Also these may very well fit 73-87 as they are very similar frame and cab setup.
dhart is offline   Reply With Quote
Old 06-15-2013, 06:38 PM   #2
VA72C10
VA72C10
VA72C10's Avatar
Re: Big Block Tig Welded Custom Exhaust..
are there mufflers with it or just as shown? Does it go all the way to the rear or stop after the x in the pictures?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-15-2013, 06:48 PM   #3
dhart
dhart's Avatar
No mufflers, it was set up with Magnaflow 3 inch band clamped on with turn downs just in front of the rear diff. They can be taken over the rear or use just as they were set up previously. The truck they came off of had a braced Currie rear diff and stainless tank so over the rear would not work on it but again they can be finished whatever way you like as the muffler mount is in the right position.
Old 06-15-2013, 08:22 PM   #4
darkhorse970
darkhorse970's Avatar
Do you have any pics of it installed on the truck?
Keith
SOLD - 1963 C10 Short Fleet
350/700R4
4/6 drop
1967 GMC Super Custom - Short Fleet
COPO concept w/427 BBC
T-400 w/Doug Nash overdrive
4/6 Drop, Buddy Buckets, etc...
Frame Off (In Progress)
I call it "Vulgar Display of Power"
1980 Silverado
Original paint
49k Original miles
4/6 drop
Check out my build thread here: http://67-72chevytrucks.com/vboard/s...=1#post6209941
darkhorse970 is offline   Reply With Quote
Old 06-16-2013, 01:50 PM   #5
dhart
dhart's Avatar
Here is a link to the original build. After the engine work was complete a full frame off restoration was done all top shelf parts.
http://www.hotrodsolutions.net/ChevyC10page2.html
Old 06-18-2013, 09:15 PM   #6
dhart
dhart's Avatar
bump
Old 06-20-2013, 08:19 PM   #7
dhart
dhart's Avatar
To dA top
Old 06-21-2013, 08:47 AM   #8
dhart
dhart's Avatar
Ttt
Old 06-22-2013, 09:53 AM   #9
dhart
dhart's Avatar
back to da top
Old 06-23-2013, 12:34 AM   #10
Critterman71
Critterman71's Avatar
Think these might fit a 71 3/4 ton?
Critterman71 is offline   Reply With Quote
Old 06-23-2013, 09:34 AM   #11
dhart
dhart's Avatar
I think they will, you can check with some other members but the frame and cab geometry is the same far as I know on 3/4 or half ton. I have never seen any parts that I scabbed off a 3/4 be any different besides hubs springs and such. Let me know it is a nice setup.
Old 06-24-2013, 02:14 PM   #12
dhart
dhart's Avatar
back to da top
Old 06-26-2013, 10:59 AM   #13
dhart
dhart's Avatar
Look
Old 06-27-2013, 09:12 PM   #14
dhart
dhart's Avatar
Back up top
Old 06-29-2013, 10:24 PM   #15
dhart
dhart's Avatar
Weekend bump
Old 06-30-2013, 03:27 PM   #16
dhart
dhart's Avatar
look look
Old 07-03-2013, 03:34 PM   #17
dhart
dhart's Avatar
Look!
Old 07-03-2013, 10:42 PM   #18
Critterman71
I would love to have them as they will work on my 3/4 ton with a slight brake line mod on the drivers side but at a total of 975.00 ( and they are worth it for sure) I just cant swing it as I bought a high end transmission last week. Good luck on the sale.
Old 07-04-2013, 01:51 PM   #19
dhart
dhart's Avatar
Yep I understand I saw the Trans you bought very nice you will really enjoy the 4l80 if I didn't have this th400 and gear vendors that is what I would get that was a good price on it too there not inexpensive to build.
Make an offer on the exhaust if interested.......
Old 07-12-2013, 10:26 PM   #20
dhart
dhart's Avatar
Back too da top
Old 07-21-2013, 11:22 PM   #21
dhart
dhart's Avatar
lOOk
Old 08-11-2013, 10:42 AM   #22
dhart
dhart's Avatar
need exhaust?
Old 08-12-2013, 08:39 PM   #23
dhart
dhart's Avatar
Ttt
Old 08-17-2013, 09:49 AM   #24
dhart
dhart's Avatar
back to da top
Old 09-07-2013, 02:58 PM   #25
dhart
dhart's Avatar
Reduced price! cant hardly but a set of Hooker Super Comp for this price!
