Old 06-15-2013, 07:12 PM   #1
supercharged
supercharged's Avatar
Talking Tired and Confused
First let me state that tire and wheel sized confuse the heck out of me.
I just brought home a 66 C10 that is wearing P275/60R15 in the rear and P295/50R15 in the front.
I am not a big fan of chrome wheels but for now its what it has.
In fact the truck came with a full set (4) of the P275/60R15 and P295/50R15, wheel tire combos. So I am thinking about selling/trading the current tires and wheels and going to steel wheels. I also want to go with a larger and wide tire in the back than in the front and possible go with narrow white walls all the way round.
So my question is what size wheel/tire combos should I run to acheive the look I am after?
Supercharged Scottsman
Scottish by birth, American by law,
Texan by the grace of God.
“To avoid criticism say nothing, do nothing, be nothing.”
― Aristotle
supercharged is offline   Reply With Quote
Old 06-16-2013, 04:09 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: Tired and Confused
I don't have a 60-66 truck,... so you might have to ask your question over in that area.
Look here:
http://67-72chevytrucks.com/vboard/s...d.php?t=379110
Keith
Convert to disc brakes.
Old 06-16-2013, 04:24 PM   #3
cubber
Do you want your tires to stick out past the fenders or stay tucked? You can also do a lot with different wheel backspacing.
=MATTHEW
69 Stepper...Stroked & Bagged GONE BUT NOT FORGOTTEN
2003 Chevrolet Z71 Ext. Cab
1995 Cavalier gas saver!
cubber is offline   Reply With Quote
Old 06-17-2013, 10:11 PM   #4
supercharged
No just a classic rake
― Aristotle
Old 06-18-2013, 04:08 PM   #5
cubber
Those wheels on the back look like they are sticking out a bit, and from what you said the fronts have wider tires. Looks like the backspacing is different on the wheels. For starters, I wold put thefronts on the back, and then take two of the smaller tires and put them on the wheels that match, and stick them up front. I assune the wheels and tires you have in the back of the truck are the other ones that complete the sets. I would put two 295's and two 275's on each set of wheels, then you can see which wheel backspacing you prefer.
=MATTHEW
Old 06-18-2013, 04:10 PM   #6
cubber
I had 255/70's all around on my truck before I bagged it, and they looked great! Are you planning on lowering the truck?
=MATTHEW
Old 06-18-2013, 05:01 PM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I squished some 325/50/15's on a 12 wide wheel. Definately staggered.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-20-2013, 02:34 PM   #8
ob1monkey
I am not sure what sizes come with white walls, but if the 275/60's are good I would sell/chuck the rest and put 255/60 on the front or even 245/60. both will still have plenty of tread and be just a little shorter.
ob1monkey is offline   Reply With Quote
Old 06-22-2013, 03:08 PM   #9
supercharged
I double checked and what is on the truck now are P225/70R15s in the front and P275/60R15s in the rear.
I was doing some research and was looking at P155/60R15s or P145/65R15s in the front with steelies.
I would then just sell all of the others to pay for the two new front tires.
How do you think that would look?
― Aristotle
Old 06-22-2013, 07:27 PM   #10
wraprail
wraprail's Avatar
155/60 or 145/65 are way too short to use on your truck. Plus I seriously doubt you can find those sizes with a white wall.
Those sizes are for lowered VW Beatles.
wraprail is offline   Reply With Quote
Old 06-22-2013, 08:07 PM   #11
LONGHAIR
The best I can tell by the pic you posted, you have 6 lugs on the rear and 5 on the front.....
Personally, I would get that sorted first.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 06-23-2013, 12:57 AM   #12
cubber
Smallest tire you need to run (my opinion) is 235/75/15. These are cheap, and easy to get in a whitewall. They look decent on all 4 corners with steelies. However, if you do have different lugs front and rear, I'm with Mr. LONGHAIR on addressing that first. Otherwise, it will lead to unnecessary confusion.
=MATTHEW
Old 06-23-2013, 02:33 PM   #13
supercharged
No they are all 6-Lugs
― Aristotle
Old 06-23-2013, 02:38 PM   #14
supercharged
But 235/75/15 are bigger than what I am running now!
― Aristotle
Old 06-23-2013, 02:46 PM   #15
cubber
Yes, but the 235's are close to what came on them originally. The front tires on there now look a little small to me, but you may like them.
=MATTHEW
Old 06-23-2013, 03:02 PM   #16
slow-1
slow-1's Avatar
Take a closer look at you pic...I see 5 in the front too.
slow-1 is offline   Reply With Quote
Old 06-23-2013, 03:03 PM   #17
oldman3
oldman3's Avatar
I'm old and wear glasses, but the pic in post #1, front wheel is 5 lug, you running an adapter on the front????....Jim
oldman3 is offline   Reply With Quote
Old 06-28-2013, 04:49 PM   #18
knomadd
knomadd's Avatar
Unless you meant you have 5 lug all the way around, I'm with the other guys. You need to fix the different lug patterns since the front is obviously 5 lug from the pic you posted.
As Cubber had suggested, 235's came on your truck originally, so putting a narrower tire on it will not give you a favorable ride/handling. For traction and handling wider is almost always better. I can't think of when a narrower tire would be better, but I'm sure if I said "always" someone would point out my error.
Your 225/70/15 tires are 1.5" shorter and 0.4" narrower than factory. Your 275/60/15 are 0.9" shorter and 1.5" wider than factory. A shorter tire will make your speedo read slower while taller reads faster. Width is really a handling/aesthetic feature.
Good luck with your decision. Remember, you're the one that will need to be happy with your purchase.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 06-28-2013, 10:53 PM   #19
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
A great combo, which I have run on several of my trucks is....
235/75-15 in the rear. That is stock size. It keeps the gearing and speedo factory.
215/75-15 on the front. This is a bit shorter and narrower than the rear. Gives plenty of clearance for any future lowering you might do.
The advantage to these sizes are that they are available in thin whitewalls from your local Discount Tire store. You can find them in both sizes in the same tire so tread and appearance are the same. And, they're cheap. You cant buy cheaper tires than those. I just bought a pair of the 215 whitewalls from Discount Tire for 126 dollars total out the door.
