Old 06-15-2013, 07:55 PM   #1
04 orange
04 orange's Avatar
Cab pressure vent??
Going to weld up the kick panel vents on my 68 truck, so the cab is going to be completley sealed. Was thinking about adding the 71-72 style pressure vents to the B pillers on both sides. My question is are they that criitical? Do i actually need to add those, or just role with it sealed?
04 orange is offline   Reply With Quote
Old 06-15-2013, 08:05 PM   #2
da-burb
"Ochre Ogre"
da-burb's Avatar
Re: Cab pressure vent??
probably depends on how tight your cab is sealed. There are still going to be some leaks at the windows and door gaskets. But you can't push air into a closed cabin without the air already in there going somewhere else. Heating and cooling would be less effective.
Bowtie Truck Stop Inc.
Mid-West GM Truck Restoration Parts Supplier
Your Key Parts, Auto Metal Direct, Dynacorn,
and Goodmark dealer.
like us @ www.facebook.com/BowtieTruckStop
1971 C-10 Suburban (Ochre)
1971 K-10 Suburban (Ochre)
1972 C-10 Suburban (Ochre)
1972 K-20 Suburban (Yellow- that just aint right!)
Springfield, Minnesota 56087
da-burb is offline   Reply With Quote
Old 06-15-2013, 08:09 PM   #3
turp mcspray
turp mcspray's Avatar
I remember having a 67, and unless a window was cracked, the doors were HARD to shut. So it does relieve pressure in that respect as well.
Turp Mcspray
New life for an old 2wd, farm blazer
http://67-72chevytrucks.com/vboard/s...d.php?t=505987
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299
turp mcspray is offline   Reply With Quote
