Old 06-16-2013, 12:06 AM   #1
Roostboy102
Roostboy102's Avatar
Ground to pcm makes it run right?
What do I have wrong if my pcm needs a ground wire? Yes, the actual pcm! Once this is grounded all is well and it runs great. I came upon this with a LOT of trial and error!
72 C10 - Multicolor, 4.8 ls, NV3500. Sold
72 K5 - Under Construction
Roostboy102 is offline   Reply With Quote
Old 06-16-2013, 03:47 AM   #2
truckdude239
truckdude239's Avatar
Re: Ground to pcm makes it run right?
Runn a wire?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-16-2013, 04:30 AM   #3
Russell
Professional Grade
Russell's Avatar
I have heard of similar happenings if you accidentally overload and burn out the internal ground on an Allison TCM by boosting through the TCM's cooling fins by accident. I suppose it is possible the same thing could happen to a PCM, but I have not heard of it before.
As suggested just above me, folks who have accidentally fried their TCM's internal ground are able to get it to work fine by running a ground strap from the TCM's cooling fins to chassis ground. Its kind of a hokey way of doing things, but it'll do until you decide to buy a new PCM...
BTW, I have EFI Live and I can download the software on your PCM and transfer it to a new PCM for the cost of a license if you want. It's something like 120 to 130 bucks for a license.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 06-16-2013, 08:03 AM   #4
Roostboy102
Ok I mean I have a wire on it, it just didn't seem right so I thought I would ask.
