Old 06-16-2013, 12:10 AM   #1
Cmalone
Cmalone's Avatar
Rearend gears
Is anyone running 3.73 rear gears with a th350? Wanting to know what RPMs your running at 60 mph?
Cmalone is offline   Reply With Quote
Old 06-16-2013, 12:14 AM   #2
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Re: Rearend gears
I am... around 3,000 to 3,200 if I remember right.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is online now   Reply With Quote
Old 06-16-2013, 03:47 AM   #3
SS Tim
SS Tim's Avatar
Re: Rearend gears
Lot of trucks came stock with 3.73 gears. Here is a calculator to run the numbers for your specific setup.
http://www.summitracing.com/expertad...tio-calculator
SS Tim is offline   Reply With Quote
Old 06-17-2013, 02:06 AM   #4
ReeseBobby
ReeseBobby's Avatar
Re: Rearend gears
I just installed a 3.73 rear end. It's about 2700 at 60 with 33's.
ReeseBobby is offline   Reply With Quote
Old 06-17-2013, 01:57 PM   #5
Dano69c10
Dano69c10's Avatar
Re: Rearend gears
What rpm is ideal for long stretches of time on a flat highway w/o blowing up a stock 350 v-8?
2500?
Thanx in advance
Dano
'69 Fleet
It ain't yours, if you didn't build it!
Dano69c10 is offline   Reply With Quote
Old 06-17-2013, 02:08 PM   #6
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: Rearend gears
For highway driving, the lower the rpm the better as long as you don't get down too far under 1800 or so. You don't want the engine to be wound up tight but you also don't want to be loading it all the time by lugging it. In my opinion, 3000 rpm for sustained driving is way too much. 2000 is much more pleasant and easier on the engine in the long haul.
Old 06-17-2013, 04:26 PM   #7
srvivor71
srvivor71's Avatar
Re: Rearend gears
Great tool! That's a keeper. Thanks for posting.
srvivor71 is offline   Reply With Quote
