Old 06-16-2013, 01:26 AM   #1
Seventy468
almost scrap
Seventy468's Avatar
87 to 79 tub swap
Currently looking at a clean 87 tub to swap over on my 79. The goal is to stay original looking as possible. I know the 80's used a different style hood hinge that recessed into the cowl. My question is, with the dog house and cowl removed can you tell a difference in the 87 and 79 body/tub? any help is appreciated, if you know what I am talking about and would rather suggest a few words to type in the search box I am up for that also. Didn't have much luck on a clear answer searching on my own.
Thanks.
Seventy468 is offline   Reply With Quote
Old 06-16-2013, 01:29 AM   #2
Seventy468
almost scrap
Seventy468's Avatar
Re: 87 to 79 tub swap
K5 Blazer is is what I am speaking of****
Old 06-16-2013, 01:58 PM   #3
Liddy71
Liddy71's Avatar
nothing i know of
Liddy71 is offline   Reply With Quote
Old 06-16-2013, 02:51 PM   #4
Seventy468
almost scrap
Seventy468's Avatar
by chance do you or anyone know how the cowls differ? I can go look at my 79 no problem, but i do not have access to a 80's model. info/pics whatever you got is greatly appreciated. If this deal goes through I will be doing a resto thread.. thanks again.
Old 06-16-2013, 06:02 PM   #5
Liddy71
Liddy71's Avatar
I took some not much help cowl cover on it
Old 06-16-2013, 06:05 PM   #6
Liddy71
Liddy71's Avatar
there like a hole about 1" or so wide about 5 to 6" long very easy to do away with a pieces of metal welded in finish it off. the fender bolts up the same
Old 06-16-2013, 10:31 PM   #7
Seventy468
almost scrap
Seventy468's Avatar
hey that helps a lot, thank you all for your help.
Old 06-17-2013, 10:07 AM   #8
Jonboy
Slots go on anything!
Yep. Patch that spot on both sides, and you should be good. The floor hump will be different around the shifter, so just unbolt and swap yours over. The floor will be the same, so that will eb easy. Make sure you don't mix up the body mounts, they are differen heights on the 73-80 and 81 up pickups. That might not be an issue on a Blazer, but measure them to be sure.
