Disc brakes, master cyl
Is this the right master for a 67 C-10 with a 71 C-10 disc set up? Or do I need the big/little resavoir type master? Got a part #? Thanks
'69 SWB '76 International "Terra" "Hooked on holiday beer" |
I've seen both types used.
WELL NOW
My disc setup has the other master on it I belive these were for the drum setup only.I read a while back that someone was using this type on a disc setup and I don't know why it wouldn't work on either setup.But for a whopping $11.94 you can get a new 1 for disc brakes at Advance Auto and put the mystery to rest,Hope this helps GOOD LUCK
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
its all about the +6 inches
You should have the larger resivour type for discs.
The caliper uses the fluid for adjustment in all basic terms, so you will need quite a bit more in order to adjust them and maintain enough in the master to keep them working. In all reality, there is a chance of sucking that thing dry when the pads get worn. |
I was under the impression that the different master cylinders were made by different suppliers & they had to be compatible with that supplier's boosters. My 79 Sub has the 2-bail type, & my friend's 75 P/U has the other one. Both work fine.
one bail two bail doesn't matter...it is the size of the resivour I am refering to.
"Trucks with Class"
![]() Join Date: Jul 2000
LOOKS RIGHT
There were two for DB. That looks like one of them. The overall size is much larger than the one for drum brakes. Is there a bigger chamber on one end under the cap?
