Old 06-16-2013, 01:47 PM   #1
warndogg
warndogg's Avatar
drum or disk?
I purchased a 70' swb with 4 wheel power drums. Not sure what to do with the brake system. On inspection I need shoes all the way around as well as the small rubber brake lines at the spindles, also springs (they look original). Both front bearings need to be replaced. And I have oil on the power booster so probably the M/C is leaking and prop valve.
With all that said I have been looking at all the great info on here about the "bolt on" spindle and axle kits from various vendors. Just not sure if I want to spend the extra on disc conversion. Other than greater wheel options, are discs really that much better? Also are these true bolt on kits or am I going to spend hours fabing things?
P.S. this is coming from a novice garage mechanic with basic tools.
warndogg is offline   Reply With Quote
Old 06-16-2013, 02:38 PM   #2
ecgate
ecgate's Avatar
Re: drum or disk?
Disc are way easier to assemble than drum brakes. I have a disc kit from POL and it is a true bolt on kit. I had no problems at all. With that said I think going disc is a no brainer.
ecgate is offline   Reply With Quote
Old 06-16-2013, 03:50 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: drum or disk?
GM went to disc brakes on the 1971 model trucks.
That was 42+ years ago.
Time to upgrade,...
Keith
Convert to disc brakes.
Old 06-16-2013, 09:16 PM   #4
70cst
70cst's Avatar
Re: drum or disk?
My vote is disc
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 06-16-2013, 09:32 PM   #5
volksworld
Re: drum or disk?
don't even think of staying with drums...I converted mine 32 years ago...suggestion for a novice,break the job into segments...do master and valve ,bleed and test drive, then fronts or rears ,bleed and drive then do remaining axle...this way you avoid the "I replaced everything its all new I've been trying to bleed the brakes for 3 days I have no pedal what do you guys think is the problem?" situation. as long as you had a pedal when you started you can figure out when you screwed up or installed the defective part .one of my favorites was a wheel cylinder where the bleeder hole was never drilled...outside ,after dark in the snow...
volksworld is offline   Reply With Quote
Old 06-16-2013, 10:26 PM   #6
warndogg
warndogg's Avatar
Re: drum or disk?
Thanks for the replies! I guess I have my answer.
Old 06-16-2013, 11:15 PM   #7
c10Dream'n
c10Dream'n's Avatar
Re: drum or disk?
another vote for disc...
c10Dream'n is offline   Reply With Quote
Old 06-16-2013, 11:31 PM   #8
67ChevyRedneck
67ChevyRedneck's Avatar
Re: drum or disk?
Yup, you need to do it. I drove mine with drums for 5 years, and the last 11 with disc. No comparison.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 06-17-2013, 01:15 PM   #9
c10srule
c10srule's Avatar
Re: drum or disk?
go with disc, you can get 6 or 5 lug rotors depending on your preference
c10srule is offline   Reply With Quote
Old 06-17-2013, 01:34 PM   #10
Jerryrig
Jerryrig's Avatar
Re: drum or disk?
+1 for disc....
about to update my build thread in the next few days because i just did this conversion.
1970 Chevy C10 Fleetside SWB
1998 Dodge Viper RT10
1999 Harley Road King
2006 Ford F250 CC SWB
2008 GMC Yukon Denali
My Build Thread
Jerryrig is offline   Reply With Quote
Old 06-17-2013, 01:46 PM   #11
nlped
nlped's Avatar
Re: drum or disk?
Mine was 4 wheel power drum when I bought it and drove it home... They were sketchy AT BEST. I now have 13" 4 wheel disc brakes with the appropriate m/c & p/v. It's like night & day. I vote to at least go to front disc, but this is when you need to decide if you'll stay 6 lug or if you're gonna go 5 lug.
Carter
1968 Chevy SWB Fleet... Walt
1963-1/2 Ford Falcon Futura...Martha
nlped is offline   Reply With Quote
Old 06-17-2013, 01:51 PM   #12
warndogg
warndogg's Avatar
Re: drum or disk?
I definitely want to go 4 way disc and swap to 5 lug. I need to find a local shop as I don't have the space. @nlped curious what was your total parts cost? I'll look forward to reading your build thread.
Old 06-17-2013, 03:18 PM   #13
nlped
nlped's Avatar
Re: drum or disk?
Gosh, I don't really know how to price it, as I bought the parts a piece or 2 at a time. I bought the McGaughy brake kits (front included 2 1/2" drop spindles) from Stylintrucks.com for about $1000 on sale. Then the m/c & p/v came from CPP for about $120 and then I also bought new brake hard lines from inlinetube.com for $155. So about $1300 got the parts and I installed all the parts myself and added other pieces/parts as I went to fix the steering and suspension issues I ran into.
Carter
Old 06-17-2013, 03:39 PM   #14
CC69Rat
CC69Rat's Avatar
Re: drum or disk?
Another 4wheel disc swap here, I have the same kit (basically) as Ed ^^
I paid ~$1800 for mine, all things considered. That's 2.5" dropped spindles included, as well as Hotchkis 2" F and 6"R dropped springs. The $1800 number was all of this, including shipping. The only thing it did not include was a power booster (if you want to run one) or a M/C. Pics in my GMC build thread.
The only thing I don't really care for on the McGaughys kit is the brake pad surface is not as big as the surface on the rotor.. so you lose a little brake efficiency. I'm looking right now for some kind of way to cross reference another brake pad to use with this caliper that might be a little larger and come closer to fully utilizing 'Big Brakes' and not wasting any of what this kit could truly be.
Wilwood and Baer make some SWEET stuff too, it just depends on the budget I guess.
My Pop and I took my GMC out the other day to Burnish' the brakes. Pop told me just roll along up to this redlight and push the brakes pretty good. I had to let off to keep him off of the dash / windshield. I'm telling you man .. the McGaughys kit will stand the truck on the front bumper. .. and it could be better ..
I cant imagine Wilwood / Baer .. or some of the more pricey stuff out there. I don't have enough GO to justify that much WHOA if you know what I mean. Supercharged LS3 running Road Atlanta (?) I'd definitely look at bigger brakes that what I have on mine. Every day driver, stock discs would be more than you'd ever need. Occasional cones, messin around on a curvy mountain road .. the McGaughys stuff is awesome. I guess you get what you pay for.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-18-2013, 11:24 PM   #15
warndogg
warndogg's Avatar
Re: drum or disk?
Thanks for all the input on here guys! Another related question: I like the stance the previous owner had on this truck, unfortunately with cut coils its not the best ride. Is there some way to reference my current amount of drop? Looks like I got about little over 1 inch from a arm to frame.
Old 06-19-2013, 10:41 AM   #16
dmw319
Re: drum or disk?
i went from 4 power drum brakes to just converting the fronts to disc and its much more of a safer truck now! maybe someday ill do the rears but you can do it a little at a time. its not too bad and im just basically just a garage mechanic too.
also post some pics and we can help tell you what lowering springs to get!
1970 Chevy C-10 Stepside
My build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=528167
dmw319 is offline   Reply With Quote
Old 06-19-2013, 11:09 AM   #17
Lattimer
Lattimer's Avatar
Re: drum or disk?
I want to do disks someday, but for now I just rebuilt my drums. This is mostly because my wheels won't clear disks, and I really don't feel like messing with it right now. It stops decent with all new stuff in the front, and my truck is basically a cruiser and will never tow and barely haul anything.
Down the road when its time for brakes again I will do the swap.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
