![]() Join Date: Mar 2000
Brake booster rubber boot/bellows
A couple of brake boosters I have need the rubber boot or bellows on the input side push rod replaced and for the life of me I can't find any info on brake boosters anywhere. The two I have are the Delco units from 72 that have the gold/silver plating and the plastic deally sticking out the back that the boot covers over. The older boosters (69-70) that are not plated but rather in black paint don't seem to ever need a new boot and it is different than the newer 72 type units use anyway. Does anybody know where to find these elusive rubber parts? I have also noticed that there must be a foam rubber part that wraps around the pushrod as well. These are disintegrating and will need replacing as well. Any help is appreciated.
Saskatoon, Saskatchewan Canada |
"Ochre Ogre"
I have never found this part all by it's self. I looked everywhere that I could think of. I was told if you purchase a booster rebuild kit you will find those parts in it. I found on at a junk yard. The booster was just lying there and the boot was good.
The foam piece is just a simple air filter. That you can make from any similar type product. It is there to keep dust from entering the back side of the booster and ruining the rubber diaphrams.
Bowtie Truck Stop Inc. Mid-West GM Truck Restoration Parts Supplier Your Key Parts, Auto Metal Direct, Dynacorn, and Goodmark dealer. like us @ www.facebook.com/BowtieTruckStop 1971 C-10 Suburban (Ochre) 1971 K-10 Suburban (Ochre) 1972 C-10 Suburban (Ochre) 1972 K-20 Suburban (Yellow- that just aint right!) Springfield, Minnesota 56087 |
ttt
