Old 06-16-2013, 08:08 PM   #1
kelz702
My 72 c20 350 started idling rough
For the last 2 months(since I had the timing and carb dialed in for me) , my 72 c20 350 has been running like a dream. Before that, it was idling funny and it wasn't able to pass smog. The mechanic i took it to said the timing and carb were off and adjusted them. Yesterday I was on my way home and the truck died on the road. It took me awhile, but I got it started. It was idling weird and there was a lot of black smoke coming out. I got it back on the road and drove it home. At first it was running rough but it started running good. Now when I start it doesn't sound right. I've checked for vacuum leaks(the best I could). I also changed the fuel filter and shot the carb with some cleaner. Since I bought the truck I've put on a new Edelbrok 600cfm w/ electronic choke, new fuel pump, fuel filter, new gas tank and sending unit. I'm hoping someone can help point me in the right direction. Thanks
kelz702 is offline   Reply With Quote
Old 06-16-2013, 08:17 PM   #2
cdowns
cdowns's Avatar
Re: My 72 c20 350 started idling rough
with black smoke it sounds like very rich condition// wwhat type of fuel pump did u use// edelbrrock carbs are best at about 5lb pressure
Old 06-16-2013, 08:41 PM   #3
kelz702
I think the black smoke happend because I may have flooded it while I was trying to get it started. There isn't anymore black smoke coming from the exhaust. The fuel pump is a $22 mechanical fuel pump I got from AutoZone. It's the second one I put on. I had sediment in the old gas tank and I think it was tearing up the pumps.
