Old 06-16-2013, 08:14 PM   #1
HarleyT
Booster/ master options
So ran into a problem, using the holley accesory brackets and it puts the alternator up high and it now hits the master. My thoughts where either a hydro boost or manual brakes. I only have 15 inches from the firewall till the back of the alternator. Any ideas? Really do not want manual brakes!
HarleyT is offline   Reply With Quote
Old 06-16-2013, 09:01 PM   #2
davidfre21
Re: Booster/ master options
They make brackets to mount your brake system behind the firewall or on the frame rail. I've always hated the idea of manual brakes myself. Non abs and manual brakes sounds pretty dangerous if you ever really have to stop.
Is your booster mounted directly to the firewall? You could possibly shift the booster sideways on the firewall also. A lot of s10 guys do it for some added clearance.
davidfre21 is offline   Reply With Quote
Old 06-16-2013, 10:20 PM   #3
Jimbabwe
Jimbabwe's Avatar
CaptainFab booster bracket is only 2" deep.
http://67-72chevytrucks.com/vboard/s...d.php?t=347484
Jimbabwe is offline   Reply With Quote
Old 06-16-2013, 11:28 PM   #4
BossHogg69
motor exploder
BossHogg69's Avatar
What size booster is that? It seems to have a small diameter, but is massive from front to back.
How 'bout some more pics of that front suspension...? Looks pretty sweet from what I can tell.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 06-17-2013, 11:48 AM   #5
HarleyT
I thought about the street rod style boosters and brackets that mount on the frame. but I cannot put it under the floor not enough room.
I got the booster and master from a board member " pickmup" if I remember correctly. The booster is around 9 inch diameter but just really long plus the firewall bracket adds a couple inches to. The picture makes it look massive but it really is not. Ill post some pics of the front end , it a porterbuilt c4 with air ride
Old 06-17-2013, 12:22 PM   #6
BossHogg69
motor exploder
BossHogg69's Avatar
FWIW, I'm using a hydro-boost setup with a CPP master cylinder I got from Jim at www.hydratechbraking.com - he was awesome to deal with and really knows his stuff if you decide to go that route. Seems like with the right bracket, you'll be able to make your setup fit.
Adam
Old 06-17-2013, 08:54 PM   #7
HarleyT
Looks like ill be getting a hydro boost, thanks for the help!
Old 06-17-2013, 10:10 PM   #8
wraprail
wraprail's Avatar
Why is everyone so afraid of manual brakes? You guys must all drive cadillacs or something. I have had manual 4 wheel disc brakes for years, not because of clearance issues but they are more fun.
wraprail is offline   Reply With Quote
