Old 06-16-2013, 08:17 PM   #1
Gus350
68 C 10
Gus350's Avatar
Which rear end do I have
Took the axels out and drum brakes off to rebuild with disc brakes. Need to know if I have to older rear end or the newer one measures 57 inches from plate to plate. Name:  image.jpg
Kevin
"Life is Hard But its Harder when your Stupid"
John Wayne
68 C10
70 C20
http://67-72chevytrucks.com/vboard/s....php?t=602326#
Gus350 is offline   Reply With Quote
Old 06-16-2013, 08:22 PM   #2
uncle
Re: Which rear end do I have
If 12 bolt its 70-72. 5 lug 71-72
uncle is offline   Reply With Quote
Old 06-16-2013, 08:23 PM   #3
Gus350
68 C 10
Gus350's Avatar
It is a 12 bolt.
Kevin
John Wayne
68 C10
70 C20
Old 06-16-2013, 08:26 PM   #4
CC69Rat
CC69Rat's Avatar
Measure your axles from the mounting surface (where the back side of the wheel would make contact) to the end of the splines. The early ones are 30 1/2" Later ones were 31 5/16" (not all were 5 lug.. some 6 luggers with the longer axles)
Usually if you find the OEM 5 lug axles they will be for the later rear end. Most 5 lugs @ 30.5" are some sort of aftermarket in my experience
Hope this helps..
Chad
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 06-16-2013, 08:27 PM   #5
uncle
Widened housing in 70 still 6 lug. 71/2 5 lug.
Old 06-16-2013, 08:36 PM   #6
Gus350
68 C 10
Gus350's Avatar
Thanks chad they are the 31 5/16 inch ones
Kevin
John Wayne
68 C10
70 C20
Old 06-16-2013, 08:50 PM   #7
CC69Rat
CC69Rat's Avatar
If you're swapping out and the bolt that holds the pin breaks when you take it out.. I have the tool to fix it.
Let me know.. 85% of the time the bolt will break off down in the hole. Major PITA to fix if you don't have this tool.. you're welcome to borrow mine.
Chad
Old 06-16-2013, 09:05 PM   #8
Gus350
68 C 10
Gus350's Avatar
I got the bolt out okay but the pin broke just above the hole where the bolt goes in the pin. Where would be the best place to get a new pin.
Kevin
John Wayne
68 C10
70 C20
Old 06-16-2013, 09:13 PM   #9
CC69Rat
CC69Rat's Avatar
Eww.. I don't know. Humm
Let me look around.. PM Randy and see if maybe he has one? Post a WTB on the parts board maybe?
.. in the mean time I will see what I can come up with. What ratio is in it now?
Chad
Old 06-16-2013, 09:51 PM   #10
Gus350
68 C 10
Gus350's Avatar
Not sure what gears are in it didn't have my glasses on today couldn't read what was stamped on the main gear I guess the ratio will be stamped on there this is my first rear end rebuild so I'm learning as I go.
Thanks for the help
Kevin
John Wayne
68 C10
70 C20
