Old 06-16-2013, 09:06 PM   #1
Kingjasn
Kingjasn's Avatar
thinking about a body swap...?
So,
It's been a really long time since I have posted anything at all. My wife's work has dwindled away to about nothing, so I have had to put Maggie Mayhem (my 65 C-10) on hold. Well, I have been doing some side work, and anything I could to make some "extra" money to help more with the essentials. I have been doing some home restoration for a friend of mine, and because I am gullible, and he is a good friend, I wasn't charging him for the work I was doing. One evening he pulled up in my yard and asked if he could park a 93 F150 in my drive for a while. I had the room, and didn't have a problem with it, so I said yes. After we unloaded it, we chatted for a bit, and he said he had to go. He handed me an envelope and said I might need it, then he left. He was gone before I had time to open the envelope and find the title for the truck signed over to me!! Ok, I said all that to say this... I traded the F150 for an 82 C10. It has a 250 six shooter in it that I want for Maggie, and front disk brakes. Would It be all that difficult or even a good idea to just swap the bodies from frame to frame?
Kingjasn is offline   Reply With Quote
Old 06-17-2013, 12:43 AM   #2
Captainfab
60-66 Nut
Re: thinking about a body swap...?
Don't put your '65 body onto the '82 frame. It requires a lot of work fabricating body mounts on the frame. This basically amounts to a 3" body lift. And when you're done it looks like a stock K10.
Here is a thread I started about this same subject with pics of the one I did many years ago.
http://www.67-72chevytrucks.com/vboa...d.php?t=481023
Just switch everything you want over to your '65 frame. It really is much easier than a body swap like you're talking about.
Old 06-17-2013, 06:16 AM   #3
Kingjasn
Kingjasn's Avatar
Ok,
Thanks for saving me a really bad headache! Will all the pieces-parts work swapped over?... ie rear axle, front brakes, driveshaft length, etc.?
Old 06-17-2013, 01:28 PM   #4
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
This question needs to be put in the FAQ's.
It's easier to just roll under the newer components.
Keep the frame with the matching VIN.
66 C20 Service Truck:
