06-16-2013, 09:48 PM | #1 |
how is the inner wheel arch on the bed attached?
How does the inner wheel well on the bed attach? Not the wheel tubs but the inner structure, i know it's bolted but i think it also has some spot welds. thanks
Rust is better than rice. |
06-16-2013, 10:23 PM | #2 |
Re: how is the inner wheel arch on the bed attached?
I could be wrong but I thought the only places there was any welds were a couple places that the bed floor meets the bedsides. I think they are spot welds at that too. Everything else pretty much just bolts together on these beds.
Roy 85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818 1987 R10 shortie |
06-17-2013, 05:17 PM | #3 |
i got all the bolts out but how do i remove it do i need to remove the wheel tub?
06-17-2013, 05:32 PM | #4 |
you don't have to remove the wheel tub. There is a couple welds where the rear post attaches to the floor. It will take some reefing to get it off as the caulking does a fair job holding it on by itself.
1985 C10 2004 Avalanche |
06-17-2013, 11:05 PM | #5 |
i think you are thinking of the bed side that's not what i'm talking about.
06-17-2013, 11:06 PM | #6 |
This is what i'm talking about
06-18-2013, 07:50 AM | #7 |
Oh, they are spot welded all along all the edges. You have to drill all the spot welds out and the new one must be welded back in.
06-18-2013, 03:53 PM | #8 |
I'm just glad to be here!
yes, it is spot welded along the wheel lip and at a spot or two on the rear splash sheild.
Karl 1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues) http://67-72chevytrucks.com/vboard/s...d.php?t=372424 The LST Challenge: http://67-72chevytrucks.com/vboard/s...=1#post7812257 Korbin's 1st Square: "Sunburn" http://67-72chevytrucks.com/vboard/s...d.php?t=418618 1985 GMC Sierra: "White Trash", Korbin's 2nd now... http://67-72chevytrucks.com/vboard/s...d.php?t=632305 Henry - 1984 Chevrolet, Owen's 1st Square |
06-18-2013, 06:12 PM | #9 |
rear splash sheild?
06-18-2013, 08:02 PM | #10 |
