Old 06-16-2013, 10:40 PM   #1
luvbowties
luvbowties's Avatar
Question Want more "road-feel" with power steering
I'm using an adapted '80's GM pickup ps gear box on my '66 C-10. It has approx. 3.25-3.50 turns, lock-to-lock. Feels much better than the '70's motor home unit I first installed--it had approx. 4.25-4.50 turns, lock-to-lock.
Just got out of storage my 2002 Z-28 for its annual exercise. Its approx. 2.25 turns, lock-to-lock, has raised my curiosity and has me wanting a steering box close to the Z-28 ratio for my pickup--hoping to get a better road-feel with it.
Anybody used a suitable factory box that will interchange?
Or, used any other ways that gives a "harder-to-turn" feel?
My main desire is to get more road feel--not necessarily a quicker turn--but both results would be an even greater plus!
We've aligned the pickup, using '87(iirc) specs; I'm sure we adjusted it with much more positive caster which provided a firmer/harder-turning feel.
I recall from older swaps that some Jeep Grand Wagoneer boxes were a direct fit. Also, some models Dodge pickups would fit. I have no idea what the turns-ratios of these were.
Any ideas will be appreciated.
Sam
luvbowties is offline   Reply With Quote
Old 06-17-2013, 02:04 AM   #2
62-One-Ton
62-One-Ton's Avatar
Re: Want more "road-feel" with power steering
Rack and pinion possibly...?
Project Change of Plans: http://67-72chevytrucks.com/vboard/s...d.php?t=513135
'62 C10 SWB
'03 Express Van 5.3l Dead (parting out and using motor)
'99 Silverado 4.8l 5 speed 4wd
62-One-Ton is offline   Reply With Quote
Old 06-17-2013, 10:18 AM   #3
cortcomp
cortcomp's Avatar
I know flaming river does rack and pinion updates for cars and trucks without putting the whole mustang II front end in, just their kit to change steering, might well be something worth looking into.
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 06-17-2013, 10:26 AM   #4
Rich 5150 69
Rich 5150 69's Avatar
Unisteer mkes a good product....
http://www.unisteer.com/seach_by_veh...inion_kit.html
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 06-17-2013, 10:50 AM   #5
kieth
kieth's Avatar
I do not have the specifications but we used the box off a 01 burb 1/2 ton 2wd, I think they called it variable ratio power steering and it is pretty quick, I think about 1.5 turns lock to lock. will check to see about that and let you know. The smaller diameter wheel and the VR make it easy to handle. Kieth
kieth is offline   Reply With Quote
Old 06-17-2013, 11:10 AM   #6
luvbowties
luvbowties's Avatar
Smile Re: Want more "road-feel" with power steering
Kieth, this sounds interesting. Looking forward to more info.
Sam
Old 06-17-2013, 11:55 AM   #7
luvbowties
luvbowties's Avatar
Anyone ever used a Jeep Wagoneer, 1976, gearbox on a Chevy? Looks like it will bolt right on. BUYAUTOPARTS.COM has several listed with suffixes "LTL" which I interpret as lock-to-lock.
For the 1976 year models, it lists
Quick Ratio 2.5 LTL $325 $321.75
Quick Ratio 2.75 LTL $245 $242.55
Quick Ratio 3.0 LTL
I think these 3 are brand new units. They also list, for same application, a remanufactured one for like $188.00--but no mention of any "LTL" specs.
If these will fit in place of our GM units, that will give us 3 more choices(in addition to the 2 we all know about: the 4+ turns and the 3+ turns) of ps gear ratios for our trucks. That "2.5 LTL" unit looks especially appealing!
Anyone knowing for sure they will work, please chime in.
Thx,
Sam
Old 06-17-2013, 12:32 PM   #8
tincan1966
tincan1966's Avatar
I installed a Mustang/T-Bird power rack in my 'Burb. I made my own crossmember and mounts. I am going to try and make a bracket that will work with the OEM crossmember, too.
One thing to consider with the R & P conversion is the steering shaft from column to rack- you will need to be a bit creative around OEM engine mount towers.
Just a little bit of what I can offer on the subject.
tincan1966 is offline   Reply With Quote
Old 06-17-2013, 12:45 PM   #9
Low Elco
Call Chip at Power Steering Services in Springfield, MO. He can set a box up any way you could want it for around $200. Great guy as well. He did a '72 Monte box for me with high effort feel and quick ratio ws-6 guts. Worked perfectly, and got that tub hustlin'! look here-
http://powersteering.com/
Low Elco is offline   Reply With Quote
Old 06-17-2013, 09:57 PM   #10
bubba327
HOW long until spring??
bubba327's Avatar
I used a 97 Jeep Grand Cherokee Delphi steering box in my 69 Chevelle in place of the Saginaw. Had a few minor adaptations like the rag joint and metric hoses but it sure made a day and night difference. Is quite a bit of info on the chevelle sites.
69 chevelle convertible
71-C-10 short-wide and low
64 C-10 custom shortbox "Bubba"s Recycling project"
bubba327 is offline   Reply With Quote
