06-28-2003, 01:44 AM | #1 |
go bucks!
do i need shock relocator brackets?
doin' the 3/4 drop on the 68 1/2ton w/ coil springs.i have the drop shocks for the project,as well as the adj. track arm.question is at what point in "inches of drop" do you need to go to relocating the shock brackets in back?is this only in lowering 5" and more....(c-notching the frame type of applications)?
'68 swb 1/2t 350/350th '86 lngbd 3/4 TON parts getter '49 gmc 1/2 t 5 window 350/350th '96 gmc sonoma sle ext-cab. hey it's a 4cyl. 5 spd and good on gas y'know? |
06-28-2003, 02:30 AM | #2 |
I dropped the rear of mine 3" and it required the relocators. I could have done it w/o, but the ride quality would have suffered.
Fawker Fab three seater rock crawler buggy 498 BBC/SM465/203/205 doubler, propane, 5.13's, 42" PB Rockers '66 C10 - The new hot rod '77 3+3 Dually - 12 valve 4wd conversion tow rig project '28 Ford 2 door sedan street rod RevLimit Offroad "Hang on beer, we can do this." |
06-28-2003, 03:13 AM | #3 |
Livin' it up.
if i remember reading right the magic number is 4" so yeah i'd go for it. It wont hurt at all... in fact it'd improve ride.. because of the shock being more actively involved. good luck
-Greg; Sold the 69 C20. It's off to a better home with more love! Now onto the 86 CUCV M1009; K5 blazer with 6.2L diesel, corp 10 bolt axles, Detroit locker in the rear, trutrac front, 3.73 gears, 35" tires. |
06-28-2003, 05:57 AM | #4 |
I used the ECE shock relocation kit with 4" dropped rear coils on the Burb and it rides great. I suspect any more than 4" would require C-Notch to maintain ride quality, but could be mistaken.
06-28-2003, 11:37 AM | #5 |
I did just a spindle drop in front on mine and a 4-5" shorter coil in the rear. I just flipped the lower mounts swapping sides and used a spacer plate between them and the arms. Still run stock shocks and don't notice any lose in handling. Its down there and hugs the road corners like it is stuck to the road.
Smitty '71 Short Fleetside Spring Valley, Ca. |
06-29-2003, 10:06 PM | #6 |
go bucks!
thanks for the responses,any of you did this w/o relocating the shock mounting brackets....and how bad did it actually affect the ride?
06-29-2003, 10:15 PM | #7 |
Low & Slow
I don't have them..... I couldn't tell you how bad it is compared to with them..... my shocks and springs were shot all the way around before hand. It is i little too bouncy at times though I don't know if the relocators would help that any.
70' C-10 LWB Fleetside 4.5/6 drop |
07-02-2003, 10:28 PM | #8 |
The rides alright. After all it's no Caddy. I enjoy driving the truck every day. So I have no complaints. Might have should have used regular shocks instead of heavy duty gas. I love my truck!
