06-17-2013, 08:22 AM | #1 |
Clutch Pedal Assembly
I have all of the parts to add a clutch pedal to your truck. $60.00 shipped.
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 Last edited by JJH Jimmy; 06-21-2013 at 02:05 PM. |
06-18-2013, 03:24 PM | #2 |
Re: Clutch Pedal Assembly
Do you have the frame mount for the bell crank.I assume all that just goes in with the brake pedal?
Posted via Mobile Device |
06-18-2013, 03:29 PM | #3 |
I know i saved it, but i can't seem to find it. It is no more than a piece of angle with a notch cut in it if i remember right?
1972 GMC Jimmy 4x4 LS Swap 1985 Chevy K20 1994 GMC Yukon 2021 GMC 2500HD Duramax AT4 My "It's a Jimmy Thing" Build http://67-72chevytrucks.com/vboard/s...d.php?t=583528 Budget Build 1985 K20 http://67-72chevytrucks.com/vboard/s...d.php?t=801565 |
06-18-2013, 07:05 PM | #4 |
Yeah, that's it. I know you can just take the pedal off when putting an auto in. Can you just put the pedal on when putting a manual in? I haven't looked. Was your truck an original v8 or a 6?
06-18-2013, 09:19 PM | #5 |
I believe that all of the brake pedal supports have the sleeve in them to accept the clutch pedal and linkage. This is from a 72 Jimmy with a 350 which is the same as a truck.
06-21-2013, 02:06 PM | #6 |
Price Lowered.
06-21-2013, 02:49 PM | #7 |
Whatcha gotta have for it?
06-21-2013, 03:22 PM | #8 |
$60.00 Shipped. It will probably cost between $15 - $20 to ship.
