Sooo Confused
I ordered a DJM lowering kit week before last and decided to install it this weekend. The first thing it tells you is to check all measurements prior to installing the kit. When measuring I noticed the front passenger side was 1/2" higher than the front driver side (See pic below). I didn't think much of it as I thought the spring just didn't settle the same as the other. After installing the kit now the front passenger side is 3/4" higher than the front driver side. After scratching my head all day yesterday I noticed something that I thought was weird! I don't think the cab is sitting level on the frame or something. (See pic below) I hadn't had a chance to climb under it yet to see because I just noticed this in pictures I was looking through here at work. Any suggestions on what might be the problem?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
Re: Sooo Confused
im not an expert by any means. but id say your cab mount on the driver side is shot.
1978 2wd Fleetside, 350/th350 headers and 10 series mufflers 1998 Jeep ZJ 4.5 lift 32s full bolt ons awaiting axles "Life is full of decisions, we make them and dont look back" |
Re: Sooo Confused
Ahhh you could be right. I just looked back at the picture and the body line from the cab to the bed on the driver side is not lined up. It looks to be approx. 1/2" off
Project Heaven in my 67!!!
Re: Sooo Confused
Re: Sooo Confused
Dang that sucks!!!! I worked for an hour turning the springs under the truck trying to even the front end out....no luck
Re: Sooo Confused
Im hoping someone else has a suggestion that might help us both out. But currently mine sits just like yours and I have new body mounts under my body.
Re: Sooo Confused
Let's keep our fingers crossed!
Re: Sooo Confused
If you replace the mounts and its still off I believe you can shim the cab mounts.
Re: Sooo Confused
Trying to get these trucks level is a real pain in the butt..I would think in your case you would have no choice but to shim the cab mount. Make sure that nothing is wrong with the bed mount first.
Re: Sooo Confused
Isnt the bed mount just a bolt through the frame, with a small (1/8") spacer in between the bed and frame rail?
Re: Sooo Confused
Personally I'd start off by crawling under it and measuring the bottom of the cab to the top of the frame. Right beside all 4 cab mounts. And compare the measurements. Adjusting the bed is easy, but make sure your cab is level first is what I'm sayin
Posted via Mobile Device |
Re: Sooo Confused
sounds like a case of that famous chevy tilt
![]() . bagged and soon to be bodied 70 longbed http://67-72chevytrucks.com/vboard/s...d.php?t=564028 |
#13 |
Re: Sooo Confused
^^^x2
#14 | |
Re: Sooo Confused
#15 |
Spear and magic helmet!
Re: Sooo Confused
Before you go crazy with the cab mounts, check the rear springs. After I dropped my truck, it leaned hardcore to the driver's side. It was a bad case of Chevy lean. This comes from many decades of the driver and the gas tank on the same side, with nothing as heavy on the other side. I swapped my leafs in the rear from side to side and it's not noticeable now at all.
I don't know if you can tell from the pics, but this is before the leaf swap. If you look at the front fender bottom to tire gap on the driver's side and the passenger side, you can see it's sitting higher on the passenger side. After the swap, it's pretty much even. ![]() ![]() Last edited by killthewabbit; 06-19-2013 at 11:07 PM. Reason: Forgot the image tag |
#16 | |
Re: Sooo Confused
#17 |
Re: Sooo Confused
Good deal, man. Hope you like them as much as I do. I'm pretty happy about how it turned out and how the drop and wheels/tires are holding up. I drive it every day, and it sees a fair amount of potholes and otherwise crappy roads.
I still crack up when I think about you negotiating the purchase of your truck with the old dude outside in his tighty whiteys. |
#18 | |
Re: Sooo Confused
This truck won't be my daily driver so I am sure I will be more than happy with it. I plan on making it my "Drive to Work on Friday" vehicle.
#19 |
Re: Sooo Confused
Try flipping the leaves from the driver side to the ps and same with the springs. I had this same issue on my 82 lwb before I sold it.
#20 |
Re: Sooo Confused
Ok so I climbed under the truck yesterday (Finally) and this is what I found. Now remember that the truck was sitting a 1/2" unlevel prior to installing the drop kit. The a-arms are closer on the driver side than they are on the passenger side. Approx. 1/2"
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" Last edited by Claytona08; 06-21-2013 at 08:35 AM. |
#21 | |
Re: Sooo Confused
#22 |
Re: Sooo Confused
Aftermarket springs that came with the kit.
#23 |
Re: Sooo Confused
#24 |
At the body shop.
Re: Sooo Confused
Swap the springs up front. Or turn one in the bucket
" That didnt make it any newer " " Dont antique the equipment " |
#25 |
Re: Sooo Confused
I have the same exact issue with the old springs and the brand new springs..
