Old 06-17-2013, 02:36 PM   #1
truckdude239
truckdude239's Avatar
how to hook up gas-tank lines
whats the best way to hook these up?
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 06-17-2013, 06:51 PM   #2
Robznob11
Robznob11's Avatar
Re: how to hook up gas-tank lines
if your going to hard line get inverted flare brass connectors, and convert over to compressionon the other end. or you can use a double flare tool and put break line style fittings and just go invert to invert
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride!
........................ ___
.........________//__{\_____
,,,,,,,/__(⊙)___//___/__(O)_/
@disciple2.rc 💪instagram💪
LED TAILS
Robznob11 is offline   Reply With Quote
Old 06-17-2013, 07:56 PM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Cut them off, and flare on regular inverted flare brake line fittings. You can then run hard line 90% of the way up. On the engine side, it depends if you'll be using braided line or just using the budget fi rubber line.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 06-17-2013, 09:38 PM   #4
truckdude239
well i need to run far enough out for my corvet filter and reg tehn hard line the rest of the way
David fuller
2000 Tahoe 5.3l 378
Old 06-17-2013, 11:14 PM   #5
truckdude239
Do they need to be double flare or will single flares be okay? Im runninv a ep381 ac delo pump
David fuller
2000 Tahoe 5.3l 378
Old 06-18-2013, 09:49 AM   #6
Wasted Income
Boosted Member
Wasted Income's Avatar
Cut them off and use a compression to AN fitting.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-18-2013, 11:29 AM   #7
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Wait....your running a vetter regulator? Are you running the car intake then?
Your sig says a 4.8, which would be return style and not need the vette reg (unless its newer than 05?)
Double flare never hurts but I've run single flare on fuel systems before without any problem. Its under 100psi so its not like the braking systems at 2k+
Old 06-18-2013, 11:34 AM   #8
truckdude239
this is whati have out of a 2004 silverado
http://67-72chevytrucks.com/vboard/s...d.php?t=577190
David fuller
2000 Tahoe 5.3l 378
Old 06-18-2013, 10:08 PM   #9
68c10airstream
68c10airstream's Avatar
Hi david, i went to the junkyard and got the quick connect fittings at the intake area, cut the rubber line as far back as possible, used edelmann brass fitings that have a nice bulbous end on it, fuel injection specific clamps, bent my own lines with inverted flare like brake lines are, i used my mastercool hydralic flaring tool to make o'ring fittings for a gm fuel filter, and someone makes (maybe inline tube) an adapter to go from male oring to male oring at your sender area. Gm made that fitting on an 88 long box 4 door truck to extend their lines so i had that for a long time. I steered away from AN fittings after a couple friends have had repeated leak issues. When they saw my truck they asked me what i did for lines and said i made it like gm did, after hearing their horror stories (almost a fire) etc. I feel that a room full of gm engineers working together to produce lines that don,t leak, have to stand up to crash tests, overpressure bursting tests, emissions compliance, etc was good enough for me. I don't need fancy anodized fittings that are expensive and take special aluminum wrenches so i don't hurt them, etc. I worked as a dealer mechanic for 30 plus years and other than corrosion from road salt finally getting to them i never saw a leak. My 2 friends can't say the same. Oh david, you don't have a relative by the nickname of skip fuller do you? maybe 80ish years old? Let me know and good luck, Brian Fuller
68c10airstream is offline   Reply With Quote
Old 06-19-2013, 02:29 AM   #10
truckdude239
Nope not that i know of no skip
David fuller
2000 Tahoe 5.3l 378
