Old 06-17-2013, 05:03 PM   #1
ivorton74
ivorton74's Avatar
Changing my trans filter and fluid...need help
Decided to try and change out my trans fluid and filter this weekend but i'm kinda stuck. The oil pan is stuck...the back of the oil pan is hitting on the valve body so I cant get it out. Also I bought a trans filter kit from napa and the filter is different from the one in my trans...the one in my trans is square and the other one is actually the shape of the oil pan. so how do I get my trans oil pan off? also would that filter would in my transmission? its a th350
new filter looks like the one in the pic...
ivorton74 is offline   Reply With Quote
Old 06-18-2013, 08:14 AM   #2
Keith Seymore
Keith Seymore's Avatar
Re: Changing my trans filter and fluid...need help
Originally Posted by ivorton74 View Post
Decided to try and change out my trans fluid and filter this weekend but i'm kinda stuck. The oil pan is stuck...the back of the oil pan is hitting on the valve body so I cant get it out...
How is the pan stuck, by hitting on the valve body?
Is it trapped between the valve body and something else, like the exhaust pipe or trans crossmember?
I do seem to recall that with some of our TH350 equipped trucks we had to remove the trans crossmember to get the pan off.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 06-18-2013, 12:11 PM   #3
ivorton74
ivorton74's Avatar
yeah it was stuck on the crossmember...got it solved though...my uncle helped me undo the middle bolts on the cross member and we jacked up the back of the tranny and the pan came right off...now I think I gotta go back to the parts store and get another filter.
Old 06-18-2013, 03:08 PM   #4
INSIDIOUS '86
INSIDIOUS '86's Avatar
A bigger filter isn't a bad thing as long as it fits. Also a small neodymium magnet to drop in the pan is a good idea.
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 06-18-2013, 08:32 PM   #5
ivorton74
ivorton74's Avatar
well got it done...so far so good...no leaks yet and trans shifts and pulls good...no slipping. got the correct filter for it too.
