Resident of Here
Starter engaging while driving?
So I replaced my starter on my 88 last week. I didn't notice the knock sensor wire wrapped around it and accidentally broke it off. I left it like that and havent had any problems. Except, under hard acceleration I hear the starter engage for no more than one full second and it stops. Why is this happening? How do I fix it?
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
Resident of Here
Re: Starter engaging while driving?
Bump. Anyone?
78K & 79C Jimmys
mine broke off and it would knock,SES light would come on
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
Second Chance Program
Loose actuator wire at the starter rotating into the positive would be my bet.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
![]() Join Date: Aug 2008
Resident of Here
Ok so after having my dad ride with me and hearing it, its not the starter or a timing ping. It happens at about 2300rpm under 3/4+ throttle. It definitely is a grinding. Im clueless.
I once had the harmonic balancer rub on the front cross memeber.
Resident of Here
Could you explain that to me a little more? There is an actuator wire? Which one is that?
Detonating. Fix/replace the knock sensor wire.
