Old 06-17-2013, 07:27 PM   #1
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Straightening Steering Wheel
73-79 column, just had the alignment done and the steering wheel is sitting crooked. Is there a way to straighten the wheel, while I am going into the column for rebuild and to tighten the tilt bolts??... Without having to adjust tie rods?
Before I get "Should have been done by the alignment shop", I will say the tech told me he could not align with the toe/tie rod adjustment. ***Note*** that this is not a stock set up (using PB drop member/bags)
Thanks guys, hopefully I don't need to tear the steering apart and readjust... then re align!!
77' Chevy SB
Dropmembered Front and Rear
5.3/4l60e combo
JNJchev77 is offline   Reply With Quote
Old 06-18-2013, 01:29 AM   #2
1981Stepside
1981Stepside's Avatar
Re: Straightening Steering Wheel
Pull the steering shaft off the pump and reattach it on the spline when the wheel is straight.
Proud UA member since 2009
My LT1 Silverado build-up: http://67-72chevytrucks.com/vboard/s...d.php?t=549660
Check out my new YouTube channel! - https://youtube.com/channel/UCXk5mZOQI1sEnu5bIkhe7fA
1981Stepside is offline   Reply With Quote
Old 06-18-2013, 01:32 AM   #3
54Caddy
GM Addicted
54Caddy's Avatar
Been there done that. Whats happening is the horn pin that goes through the steering wheel holds it in center, when you installed the rack and pinion it could have been shifted to one side more that the other. what ive always done (since horn didn't work) is cut off that horn pin and move the steering wheel so that way it is straight with the alignment. you could try that or, set up truck at ride height with wheels straight then try to take off the steering joint that connects to the rack to rotate steering wheel maybe that will help a bit. I am a technician myself and sometimes it is true that there is not enough adjustment for the tie rods when steering wheel is too off center, but that's never end of the story there is always a fix for it. Nothing in steering wheel has a stop in it, if you need more help rebuilding steering column send me a pm ive done quite a few of these ones
..Mac’s Garage..
73 GMC, 54 Caddy, 2010 Silverado, 68 C10 RIP DAd
My 73 GMC Truck Build Pic
2010 Silverado 4/6 on 24s
IG:MacsGarage
54Caddy is offline   Reply With Quote
Old 06-18-2013, 04:24 AM   #4
wraprail
wraprail's Avatar
This may work to get the steering wheel straight but what about the turn signal cam? Your turn signals won't cancel when you turn or will cancel at the wrong time.
Plus some states require a working horn to pass inspection.
wraprail is offline   Reply With Quote
Old 06-18-2013, 04:41 AM   #5
wraprail
wraprail's Avatar
Your column has a 1'x48 spline on the end. IIRC there is not a indexing spline on it so you can just re-index your u-joint. You must have an aftermarket u-joint where the column connects to the steering shaft? IE: Sweet, Flaming River, Ididt, Borgeson
Old 06-18-2013, 07:31 AM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
weird
wraprail do you mean the rag joint or higher
when i did my rag on my (stock)78 it made it 180 out
doorman couldn't give me a reason why the key is on the opposite side
third one ordered,and was the same
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 06-18-2013, 11:42 AM   #7
wraprail
wraprail's Avatar
Not the rag joint.
I mean the bottom of the steering column is 1"x48 spline.
I assume he is using an aftermarket u-joint here.
He has a dropmember which uses a mustang type steering rack.
Old 06-18-2013, 11:46 AM   #8
JNJchev77
Registered Cruiser
JNJchev77's Avatar
There is an indexing spline/flat spot lol, on the end of the column shaft. I registered & insured the truck as a classic, so no inspection is required... here in AZ Yes, I have an aftermarket U-Joint from CPP...
So the signals won't turn off automatically, I'll have to do it manually each time? Hmmm.. I don't want to be one of those guys driving down the road oblivious to the turn signal flashing...
I could essentially grind a new flat spot/indexing spline after setting it straight, yes?
77' Chevy SB
5.3/4l60e combo
Old 06-18-2013, 11:48 AM   #9
JNJchev77
Registered Cruiser
JNJchev77's Avatar
Not the rag joint.
Yes, I should have mentioned the R&P...
77' Chevy SB
5.3/4l60e combo
Old 06-18-2013, 03:45 PM   #10
54Caddy
GM Addicted
54Caddy's Avatar
My truck has no horn pin. No problems at all with turn signals canceling. It takes patience to set it up but works fine.
..Mac’s Garage..
IG:MacsGarage
Old 06-18-2013, 03:52 PM   #11
JNJchev77
Registered Cruiser
JNJchev77's Avatar
I'll have a look once I'm in there.
Thanks guys!
77' Chevy SB
5.3/4l60e combo
