06-17-2013, 09:23 PM | #1 |
are bilstein 5100 gas shocks? i was told not to buy gas making sure
looking to buy some, thanks
06-18-2013, 05:06 AM | #2 |
Re: are bilstein 5100 gas shocks? i was told not to buy gas making sure
Why would you not want gas shocks?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
06-18-2013, 06:42 AM | #3 |
The gas in shocks in nitrogen, used for its stability.
Who told you not to buy gas shocks? Good luck in finding some... Are you sure they didn't say not to buy air shocks? |
06-18-2013, 08:51 AM | #4 | |
I think you are crossing terms. Lots of old-timers call air shocks "gas shocks". You don't want those. They provide extra spring force with an internal air spring. They are usually either short lived or have to be refilled often. When they first came out they were used like hydraulic bump stops are used today.
But today the term "gas shock" refers to the fact that good shocks have a relatively low pressure (85psi) nitrogen charge in a separate chamber that keeps the oil from foaming. All modern performance shocks have this feature. Although a shock can work without the nitrogen, it will not work for long before the oil foams and has greatly reduced damping effect. Here's a quote from IDP's page. A Volvo specialist that is know for their suspensions. Quote:
06-18-2013, 09:49 AM | #5 |
i can probably find the thread but they said not to buy gas shocks to be "oil" shocks.
06-18-2013, 10:14 AM | #6 | |
I think they are giving you bad advice.
06-18-2013, 10:56 AM | #7 |
06-18-2013, 12:53 PM | #8 |
the nitrogen is to prevent cavitation. you see the same thing used one dirtbikes and bicycles that take some pretty extreme abuse
GMC C15 355 SM465 3.73 80 C10 cruiser build thread 79 short stepside crew cab. big and ugly. build thread |
06-18-2013, 01:03 PM | #9 |
buy oil shocks, RS5000 Ranchos they come with the red boots you like
2008 Silverado Z71 RCSB 1991 GMC Jimmy 4x4 1976 GMC Sierra C15 SWB |
06-18-2013, 01:35 PM | #10 |
Gas Shocks Rides Rougher than Fluid Shock
06-18-2013, 03:06 PM | #11 |
Ok so your a 4x4 truck. Does your truck have dual shocks up front or is it single?
06-18-2013, 07:57 PM | #12 |
it's single up front I just want a nice ride going with a 3" lift it's made by tuff country like the above poster put on his 91 jimmy and in that video thread i posted that bad azz truck says it has a 3" lift on it.
so you guys tell me bilstein 5100s or the rancho's? you all have probably been there done that so i value your op's and will listen to them. |
06-19-2013, 02:11 AM | #13 |
I would assume the ran his are cheaper than bilsteins and are adjustable like they said above.
Rear shocks are softer valves as well so that may be worth looking into. Maybe try looking at pirate 4x4? Or suspension sub forum. Posted via Mobile Device
06-19-2013, 09:35 AM | #14 |
I can't keep up with all the threads this guy has going.....
Makes your head spin...
