Old 06-18-2013, 06:29 PM   #1
uncle
2 Non-AC Cabs For Parts
I will sell both for $250 minus seat or cut parts. Probably be around till Saturday then off to scrap. Cluster and visors not included.
uncle is offline   Reply With Quote
Old 06-18-2013, 06:31 PM   #2
uncle
Re: 2 Non-AC Cabs For Parts
2
Old 06-18-2013, 06:32 PM   #3
uncle
3
Old 06-18-2013, 06:34 PM   #4
uncle
4
Old 06-18-2013, 06:35 PM   #5
uncle
5
Old 06-18-2013, 06:36 PM   #6
uncle
6
Old 06-18-2013, 06:38 PM   #7
uncle
7
Old 06-18-2013, 06:48 PM   #8
uncle
8
Old 06-18-2013, 08:19 PM   #9
blazerboy72
If you cut them I need a piece around the upper hinge on the passenger side.
blazerboy72 is offline   Reply With Quote
Old 06-18-2013, 11:06 PM   #10
Rusbuilt
Rusbuilt's Avatar
In pic number 2 is there any rust in the fire wall or the cowl area?
Rusbuilt is offline   Reply With Quote
Old 06-19-2013, 12:29 AM   #11
68 Four on the Floor
68 Four on the Floor's Avatar
Ignition switch connector on the first cab?
68 Four on the Floor is offline   Reply With Quote
Old 06-19-2013, 01:07 AM   #12
1972K20
1972K20's Avatar
Got a good 72 driver's door?
1972K20 is offline   Reply With Quote
Old 06-19-2013, 01:10 AM   #13
VA72C10
VA72C10
VA72C10's Avatar
section around the gas filler (enough for me to unshave a filler)?
Looking for a 67-72 swb or blazer project in or around VA.
VA72C10 is offline   Reply With Quote
Old 06-19-2013, 05:49 AM   #14
uncle
Show me how big of area you want cut if you ask about cuts. I have a decent door( will get pics). Will also check ign connector this aftnoon.cowl has a little where meets cab. Will get a pic also this aftnoon.
Old 06-19-2013, 11:09 AM   #15
Rusbuilt
Rusbuilt's Avatar
Thanks looking forward to the pics
Old 06-19-2013, 05:46 PM   #16
uncle
Blazerboy where do u want cut. Rusbuilt and 1972k20 send me an email or text for pics.va72c10 how big on cut? 68 four floor you want just connector?
Old 06-19-2013, 05:46 PM   #17
Undone
Condition of rear sliding window in blue cab, weather striping and seals, price with shipping to 30530?
Undone is offline   Reply With Quote
Old 06-19-2013, 05:50 PM   #18
uncle
Undone slider in good shape but can't guarantee I can get seal out and not damage. I can bring it to monthly swap at commerce for 35 if you want
Old 06-19-2013, 05:54 PM   #19
uncle
Couple pics for blazer boy and va72c10
Old 06-19-2013, 06:01 PM   #20
blazerboy72
6" above and below the hinge should be good.
Old 06-19-2013, 06:01 PM   #21
uncle
Tttt
Old 06-19-2013, 06:03 PM   #22
uncle
Blazer boy do you need outer skin or whole pillar sect?
Old 06-19-2013, 06:15 PM   #23
blazerboy72
I need the part that the hinge attaches to over to the seam.
Old 06-19-2013, 06:40 PM   #24
Undone
Was talking about seals in the slider itself not window to cab seal. Yes I will take it. PM me a reminder for swap meet. Thanks
Old 06-19-2013, 07:18 PM   #25
master 1969 c10
Active Member
Hi on the first truck the trans hump would u cut it out
master 1969 c10 is offline   Reply With Quote
